Results 1 to 18 of 18
    Senior Member Two Rings acsgp's Avatar
    Jul 18 2014
    Singapore
    Headlamp replacement
    Let me start by saying that I searched, and couldn't find anything :)
    So the previous owner of my S4 when and put some thick 3M plastic protection over the headlamps. It's really ugly, and have now bubbled on the underside.
    Do I have to replace the entire headlamp, or is there a way to just replace the lens? I doubt I can remove the plastic cover without wrecking the lens.
    2010 S4 Avant, Forged bimotos, Brembos, Revo GB tune
    Veteran Member Four Rings GRUMPY-S4's Avatar
    Nov 16 2015
    DFW
    The protection film should come off... It doesnt????
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    Use a heat gun to make it pliable and it should remove somewhat easier.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Jul 18 2014
    Singapore
    Quote Originally Posted by GRUMPY-S4 View Post
    Quote Originally Posted by blackfunk View Post
    It's not a film, it's pretty thick. And there'll be quite a bit of residue.
    Nov 16 2015
    DFW
    I read somewhere that you can replace the lenses. Not sure where to get them though. Not a cakewalk to replace either
    Jul 18 2014
    Singapore
    Hoping to find some answers on this.
    The LEDs tend to burn a line into the back of the lenses too. Anyone know what to do about that?
    Nov 16 2015
    DFW
    Quote Originally Posted by acsgp View Post
    That I have never seen. Curious if it may be related to the 3M protection you have on
    Jul 12 2012
    Posting it in the detailers section may be more helpful.
    Established Member Two Rings alwiB8's Avatar
    Sep 22 2014
    Boulder, CO
    B8 or B8.5? I have a set of headlights I would give up for relatively cheap
    – 2015
    Sepang Blue | 6MT | Black Nappa | Nav | Sport Diff | B&O
    AWE 90mm Track | Eurocode Tranny Mount | CR-15 | Ecodes | H&R Street Performance
    ig: alwilling
    Jul 12 2012
    Shipping to Singarpore won't be cheap.
    Mar 21 2015
    2010 in his sig
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    I put some very thick protective film on the headlights of my Tacoma. Stuff was super thick and sold through weather tech. When I went to take it off I had to use my heat gun and it took a lot of time. I then had to go back with Goo Gone to get the junk left behind off. Pain in the butt for sure.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Oct 14 2012
    Empty...for now...
    SE PA
    I bought the Lamin-X brand of headlight clear film protection. It wasn't so much a film as it was a 0.030" thick translucent slab. I ultimately did not install it, but used it as a template to cut out my own Xpel Ultimate .008" thick overlays.
    I'm thinking you have the thick laminex covers on your headlights, and I have to guess that using a heat gun to loosen the adhesive would work for you.
    SOLD 2015 Daytona Gray S4
    Veteran Member Four Rings miztahsparklez's Avatar
    Dec 19 2010
    North CA
    The haze can be cleaned if you open up the headlamp housing. I have it on mine too.
    Nov 23 2014
    North Carolina
    like others have noted I'd heat gun it to make it pliable and remove. adhesive remover of some sort and after that use some high grit sand paper and water to wet sand it to look pretty again. same method of restoring lights that have a haze on them. follow with plastic compound.
    2021 Glacier White S5 Prestige Coupe - ECS Swaybars, 034 dynamic+ links, ECS tower brace, wheel spacers 12.5f 15r, CTS catted Downpipe, Wagner Intercooler, Andy_FL CF inlet pipe, EPL stage 2 E40 or 034 stage 2 E85 depending on mood
    2019 X3 M40i - Sold
    2015 Sepang S4 Prestige 6MT - sold
    Veteran Member Three Rings cchoi83's Avatar
    Nov 10 2014
    Long Island, NY
    Try to use a steam cleaner and pull at an angle, not straight outwards.
    2018 RS 3 | Nardo Gray | Crescendo Red | Dynamic Plus | Black Optic | RS Design Pkg | Tech Pkg | Dynamic Pkg
    P3 | XPEL Ultimate Full Wrap | Nanolex Si3D HD
    I swear I'm keeping this one stock.
    Eventuri CF Intake | JRZ RS PRO3 | BBS CI-R | Michelin PS4S
    Jul 18 2014
    Singapore
    Thanks for all the feedback guys, and for the offer of the headlamps. (2010 B8, so they can't fit, though I love the pattern of the LEDs in the B8.5)
    On removing the cover (too thick to call it film), prob not gonna happen as I live in a condo, and have no power source for a heat gun/hair dryer. Best is if I can just change the lens, but if need be, I'll look for a 2nd hand headlamp assembly.
    Another S4 has the same cover, and exactly the same issues arose - bubbling and the LED haze line. Could be that too much heat is trapped in the lamps.
    Oct 10 2012
    Zionsville and Saint John IN
    http://www.audizine.com/forum/showth...halogen-lights
    Just buy these and swap lenses. I upgraded from halogens to used ecodes for my 2010 a4. The used ecodes lenses were bad so I took my halogen lenses and swapped them and haven't had any issues for the last two years.
    -MRR GROUNDFORCE GF06 19X9.5 38MM 5X112 MACHINED SILVER -HANKOOK K110 VENTUS V12 245/35/19 -H&R Street Coilovers -Ecodes -OEM roof rack -Side blades -RS4 grille -Fog grille covers -13' shifter -HFC Eurocode -Stasis Exhaust -APR Stage II -10' B8 A4 AT
