Results 1 to 19 of 19
    Sep 14 2005
    NC
    Possible to see if my car is flashed or has a chip soldered on??
    Without having to take a part the ecu??
    Just curious. I know it's had the same tune since about 2002. Haha
    I think by then they were flashing the tune. But I'm just curious.
    Veteran Member Four Rings ianwpb's Avatar
    Dec 11 2010
    16 S3, 16 Q5 3.0t
    West Palm/ South Florida
    I would bet it's chipped.
    Veteran Member Four Rings cjt671's Avatar
    Dec 14 2014
    B5 S4 sedan, 2018 Q5
    PNW
    Boost gauge will tell you
    Jul 07 2009
    Alberta, Canada
    Just open it up. Takes 2 minutes.
    Sep 14 2005
    NC
    I know it's "chipped" but I want to know if they actually soldered the chip to the ecu or flashed it.
    I'm trying to avoid having to take it out.
    Jul 07 2009
    Alberta, Canada
    Quote Originally Posted by ajee622 View Post
    What are you worried about?
    Dec 10 2013
    Borden, Ontario, Canada
    That's exactly what it means. "Chipped" means a physically different chip than stock.
    Flash is exactly that. A file flashed onto the stock ECU. Just open it up to find out
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Why does it matter?
    Established Member Two Rings xwilliams23's Avatar
    Aug 05 2015
    2006 Mazda 6
    Milton
    If it's chipped you can no longer flash it.
    Maybe that's that he's wondering for
    Sent from my SM-G925W8 using Tapatalk
    Jul 07 2009
    Alberta, Canada
    Quote Originally Posted by xwilliams23 View Post
    My ECU has a new chip soldered on it. Was still able to flash a new file.
    I think it's the ones with adapter boards that cannot be flashed.
    Dec 11 2010
    16 S3, 16 Q5 3.0t
    If it's from 2002 then I'm pretty sure it has a Chip, not the stock EEPROM flashed.
    '16 Q5 3.0t S-line Daytona Grey Pearl, Black Optics, APR stage 1, Magnaflow exhaust (Looking for stock exhaust)
    '16 S3 Misano Red Pearl, Black Optics
    Gone -
    '13 Q5 2.0T Premium Plus
    '13 BMW 135Is 6MT Coupe - #387/586
    '01 S4 6MT - SRM K24's, Stock Block, E85 448/392 Mustang Dyno
    '12 A3 TDI Premium Plus
    '10 A3 Premium
    '99 A4 2.8 5MT
    Sep 14 2005
    NC
    Exactly. I'm under the impression that if it has a chip soldered to the ecu then I need to buy a stock ecu and have it flashed if I want to change programs.
    Aug 05 2015
    2006 Mazda 6
    Milton
    Yes I belive that is correct. If it's chipped I don't think it would allow you to read or write on the ECU.
    I could be wrong though.
    I belive the only way to know 100% is to open it. Or try to flash it.
    Established Member Two Rings Gotwake424's Avatar
    Dec 14 2014
    DavidhogAJ
    Philippines
    99% it's an actual soldered on chip. Just open it up and see. Or you could try doing a full read with a cable and nef that should tell you pretty quick
    Veteran Member Four Rings Yuppie's Avatar
    Feb 14 2005
    Houston, TX/ Richmond, VA
    Maybe some of these shops who offer tunes may have an oem chip that could offer if you purchase the tune. Reach out to VLM Spec and speak with Jared if you are considering re-tuning.
    2001 S4 Sil Sedan ASP Stage 3-Current
    2001.5 S4 Sil Avant Stage 3 IE Rods, CNC 2.8 heads, BW RS6 Turbos-Current
    2001.5 S4 Casa Sedan Built Motor TiAL 770-Current
    2002 S4 Pearl White Avant Stock--SOLD
    2000 S4 Nogaro Sedan EPL Stage III--SOLD
    2000 S4 Brilliant Black Sedan MTM Stage III--SOLD
    2001.5 Nogaro Sedan JFonz Tune Franken F21s--SOLD
    2001.5 Nogaro Sedan AWE Stage III--SOLD
    2001 Brilliant Black Sedan S4-K04/Rs6 Hybrid custom tuned Vast--SOLD
    Dec 11 2010
    16 S3, 16 Q5 3.0t
    Daz swapped out my old APR chip for a stock one.
    Gone -
    '10 A3 Premium
    '99 A4 2.8 5MT
    Sep 14 2005
    NC
    Quote Originally Posted by ianwpb View Post
    So you gave him your tuned apr and he gave you a stock one??
    Dec 11 2010
    16 S3, 16 Q5 3.0t
    Yeah
    Veteran Member Four Rings slowSfaux's Avatar
    Apr 26 2015
    Phoenix, AZ
    Daz is a wizard though. Mere mortals should not attempt such things.
