Results 1 to 15 of 15
    Veteran Member Four Rings MarcusDubya77's Avatar
    Feb 08 2013
    '19 Volvo XC60, '05 Honda S2000 ITBs
    Schonaich, Germany
    Shifting problem
    Symptoms are:
    Car is off and goes through all gears fine
    Car is on and 1-2 shift is either very hard or not there. All other gears seem fine. I am also able to start in second.
    I adjusted the JHM short shifter one last time to get very finite. Flywheel and clutch are both upgraded. Sound like a syncro or collar problem? Don't know if a transmission service of fluids and lube would have any effect...
    18 Catalunya RS3 Unitronic Stg 2/TCU Stg 2, APR DP & Intake, CTS Intercooler, 034 MPs, ECE Dogbone (0-60-3.18 : 1/4-11.16 on 98 RON) & 05 S2000 w/ ITB setup
    Gone, but not forgotten- 19 C43 AMG / 12 Abarth (full bolt on) / 07 JHM SC'ed / 08 Evolution X (full bolt on) / 05 M3 Dinan SC'ed / 05 LGT w/ Hybrid Turbo ......and many others!
    "Bitches... Come over here and have sex with Charlie Murphy" ~ Rick James
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    There is an updated 1-2 shift collar and second gear because the teeth can wear off to the point that you can't get into second gear at all. I would bet that is your problem.
    Just to be sure though try doing this. On flat ground with the engine off and your feet on the clutch and brake pedals, put the shifter into first gear, start the engine, let off the brake pedal. Does the car move forward or sit still? If it moves forward then your clutch is stuck engaging. If the car sits still then the clutch is fine. You have to think of manual transmission as two parts 1. the front half with the clutch and 2. the back half with the shift forks, collars, and synchros.
    Feb 08 2013
    Schonaich, Germany
    Clutch is good. Thank god.
    Feb 08 2013
    Schonaich, Germany
    Furthermore shifting 1-2 at 20 and below is fine. It's at higher RPM and when hard accelerating that it occurs..
    Veteran Member Four Rings ven0m's Avatar
    May 10 2015
    Audi RS6 c7 (Avant), Audi RS4 b7 (Sedan), Audi A4 AllRoad b8.5 (Avant)
    Slovenia
    Sounds like worn out synchros.
    Just a simple idea:
    If you try to double clutch can you engage 2nd, while moving at higher revs?
    If yes, then it's the synchros, because with matching the revs of the engine and transmission input shaft you do the synchros job.
    Jeremy Clarkson: "So when you were saying that it won’t slide, what you meant was, ‘I can’t slide it.’“
    James May: "Yes."
    Feb 08 2013
    Schonaich, Germany
    Yeah, I sure can... Ugghhhh... Time to put more into the money pit!
    May 10 2015
    Slovenia
    Get a longer 6th gear while you got the trani apart!
    There's a direct replacement gear with a ratio of 0.56 opposed to the original 0.72.
    James May: "Yes."
    Veteran Member Three Rings NYC_Legacy's Avatar
    Oct 14 2009
    AZ/NY
    Quote Originally Posted by ven0m View Post
    Is this replacement provided by Audi?
    "Brake last, finish first."
    Veteran Member Three Rings skhan91's Avatar
    Nov 13 2015
    B7 RS4, B7 A4 Avant
    i was debating doing this but its like almost $900, doesnt seem like thats worth it
    Apr 03 2010
    Northern Virginia
    Quote Originally Posted by NYC_Legacy View Post
    There is a European TDI sixth gear that fits perfectly. I have one that I am selling for $500 shipped. The ratio that I have is 0.53 instead of 0.56 so the rpms are a little lower still.
    May 10 2015
    Slovenia
    Genuine Audi sprockets from the All-Road quattro trani (if I'm not mistaken).
    I found the set for ~600€, it pays for itself if you do a lot of highway miles.
    James May: "Yes."
    Veteran Member Four Rings denis silva's Avatar
    Apr 14 2009
    2007 passat,subaru outback
    san mateo
    Seems like the same thing that was happening w me, my fixing was a full rebuild tranny w JHM!:(
    Sent from my iPhone using Tapatalklk
    Feb 08 2013
    Schonaich, Germany
    Ughhhh..
    Sep 20 2015
    Check your clutch slave and fluids before doing a transmission rebuild.
    Feb 08 2013
    Schonaich, Germany
    Shifting problem
    I am definitely thinking about the fluids. 1-2 at under 20 is still very smooth. It's not until I "get on it" that it becomes a hassle. Going to also try one last time at getting the shifter perfectly set up, although I think that it won't matter much.
