Results 1 to 11 of 11
    Registered Member One Ring Hassi's Avatar
    Mar 09 2016
    Sweden
    Lightbulb AMI not supported for RCA cable
    Hi, I have RMC MMI in my Audi A6 C7 2011 car. When I try to plug in AMI RCA cable . It reads AMI not supported.
    My car has non navi 7Q0 option.
    my question is: does it support video ?? Im going to setup anroid phone mirroring.
    Mar 09 2016
    Sweden
    Anyone :(
    Aug 29 2011
    Cape Town South Africa
    I have tried this as well and I am having the same problem. It appears that there is two types of cables.
    2014 Glacier White A7 3.0 TDI.
    Jan 26 2017
    Preston
    Hi, did you ever fix this problem? If so, what did you use...
    I have exactly the same issue.
    Sent from my SM-G935F using Tapatalk
    Mar 09 2016
    Sweden
    Yes, apparently it was the cable issue. I bought another one from Amazon for earlier MMI version . It works.
    Jan 26 2017
    Preston
    Don't suppose you have a link to which lead is the correct one? Or the differences between the two...
    Veteran Member Four Rings zcd2.7t's Avatar
    Jan 19 2010
    MI/CA
    Quote Originally Posted by S26UKS View Post
    I have the OEM Audi cable plus the required converter - setup works perfectly if you'd be interested in buying them from me...
    2022 Tesla Model 3 Performance
    2023 Genesis GV60 Performance
    2015 Q5 TDi - Torque, baby!
    (Gone) 2013 S6, Glacier White over Black.
    (Gone, never forgotten) 2011 S4 Prestige S-tronic wSTaSIS stuff
    Jan 26 2017
    Preston
    It's just the cable I need as I already bought the convertor.
    Yes that would be great thanks!
    Jan 19 2010
    MI/CA
    Yes that would be great thanks!...
    Private Message sent - thanks.
    Feb 10 2018
    Philadelphia, PA
    Anyway you can pass that along my way as well? I just bought this cable off amazon and got the same " AMI not supported"
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Jun 16 2020
    Estonia
    Hassi, are you saying there are different AMI RCA cables for MMI 3G and also for MMI 2G, which look the same? Where did you bought the MMI 2G RCA?
    I have the same problem. When i connect the AMI RCA, the car acknowledges the connection but MMI shows "not supported" behind AMI. I have 2009 C6 with MMI 3G High. Similarly to Hassi, I want to mirror my phone to MMI screen through RCA.
    I would really appreciate if anyone could give me any advice on the subject.
