Page 1 of 5 123 ... LastLast
Results 1 to 40 of 166
    Senior Member Three Rings Mat@1975's Avatar
    Jun 14 2015
    FRANCE
    S4 B8/B8.5 Heat Exchangers Overview
    Hello Guys,
    I noticed that there were sometimes divergent opinions or misunderstantings about the several heat exchangers that are on our S4's
    So: i took the initiative of staring a dedicated thread about the numerous Heat Exchangers and their functions
    First, here is a schematic overview of all possible HX's ont our S4's:
    1. Engine Water Cooler. Nothing special to say i would said.
    2. A/C fluid heat exchanger. Same observation.
    3. Supercharger water heat exchanger. It's a cooler for the S/C loop. It cools the water taht have been heated in the 2 HX on each side of the supercharger. The goal is to lower IAT.
    4. Auxilliary Water cooler. Not clear on what version it is present, but i understood that it was only on early B8 models (2010-2011 ?). It is plug in the S/C loop between sc and electric the pump. It's a sort of pre-cooler for the #3. HX.
    5. The Famous "ADS Cooler". This is a heat exchanger to cool the steering fluig (oïl) of versions specifically equiped with the "dynamic steering" option. It is only for the B8 models, as B8.5 models have Electric steering assistance.
    6. Engine Oil cooler. This device is attached to the engine block. The engine oïl exit in this plates exchanger where the engine cooling water flows through it. The Water heats up the oïl at cold start/bormal driving, and then the water cools oïl when spirited driving.
    Hope this will help.
    Please feel free to react to this first post, if there are mistakes to adress or clarifications to add.
    Best regards
    Mathieu
    S4 B8.5 AVANT | S-Tronic | Full ADS | Sport Diff | Glacier White
    MRC Stage 2 Tune | MRC TCU Tune | AMS/Alpha Cooler| AWE + AFE filter intake with airbox hole
    KW HAS Springs | H&R Sway bar F&R | Custom 14 mm Front and (13 R / 16 L) mm Rear Spacers | CR-15 Strut Brace
    OEM Rotors | Michelin PSS 255/35/19
    Q5 calipers | Goodridge SS Lines | 2-pieces Girodisc Rotors Front & Rear
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    Makes sense, I was very confused by peoples referencing in previous thread, but your chart cleared it up nicely!
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    all B8.5's don't have the Aux water cooler either. They deleted it.
    Jun 14 2015
    FRANCE
    Quote Originally Posted by chaos2984 View Post
    Yes, it's a pitty...
    It could really lower IAT more. Don't understand why they put it and then deleted it...
    Maybe one could buy all the parts of this cooler (support, air guide , hoses, and cooler) and then install it ? It could be a nice improvement then?
    BR
    Mat
    Jun 11 2014
    Pittsburgh
    so do the 2010-2011 b8s show lower IATs compared to later models?
    1552
    Jun 14 2015
    FRANCE
    Quote Originally Posted by nunzo View Post
    Good question !
    They at least must show more heat soak resistance.
    It's exactly lika adding an additional tank like in the APR, AWE, ... cooling kits...
    BR
    Mat
    Jun 14 2015
    FRANCE
    First thread edited with engine oïl cooler.
    Established Member Two Rings AmanG's Avatar
    Oct 27 2013
    Wisconsin
    Is the oil cooler present in all model years?
    Sent from my SM-N910V using Tapatalk
    Jun 14 2015
    FRANCE
    Quote Originally Posted by AmanG View Post
    I would be surprised if not. it is really a part of the engine.
    BR
    Mat
    Jun 15 2015
    Gone : MRC Audi S5 SB V6T
    Paris, France
    To complete Mat's post, here is a picture of the oil cooler, taken from my car.
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    I think all 2012s have the extra cooler for the SC. Mine does, just not sure if there was a clean cut when they went to the B8.5 facelift.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Nov 13 2014
    Wife's MK7 GTI
    Land of Gold Chains, NJ
    The b8 uses a single pass front heat exchanger and the B8.5 uses a dual pass front heat exchanger. I bet they are pretty close in performance.
    2015 S4 / Ibis / DSG / Prestige / Sports Diff / ADS suspension
    Mods: CR-15 strut bar / EC sway bars / EC end links / Alu Kruez / 034 trans insert / AMS heat exchanger kit / ECS intake / SPC upper control arms / APR stage 2
    B6 A4 / 1.8t / stage1 / coilovers / sway bars : Sold
    1987 Buick Turbo T / Big Turbo / so fast, the motor was strapped to the frame Sold
    Veteran Member Four Rings miztahsparklez's Avatar
    Dec 19 2010
    North CA
    2012 has the cooler in the driver side for sure. I think the cost to add this would be more than getting a larger exchanger to start.
    Jan 04 2013
    Phoenix, az
    Quote Originally Posted by BernanksBeard View Post
    Until you add an aftermarket unit like your AMS then the B8 would technically have more cooling than a B8.5. As someone else posted I am curious if anyone ever measured that. Two identically tuned and outfitted cars, B8 and B8.5, in the same environment to see if the IATs are different.
    Jan 14 2009
    pasadena md
    Quote Originally Posted by cspcrx View Post
    well not exactly if the B8.5 is double pass like someone has said. If you have that side radiator and a single pass main radiator you would probably get the same cooling effect as a double pass one. I bet the temps are very close to each other. The probably went to a double pass to save money with costing a little more but they are saving with the parts deletion.
    Jan 04 2013
    Phoenix, az
    Perhaps when stock.
    But when you remove the stock cooler and replace it with an aftermarket unit like one from AMS, APR, AWE, etc. that advantage is gone. They will then have the same primary cooler but the B8 will have the precooler that the B8.5 wont have.
    Senior Member Two Rings acsgp's Avatar
    Jul 18 2014
    Singapore
    Thinking aloud, would upgrading the B8 cooler to the dual pass B8.5 version, + the aux cooler lower the temps even more, without having to go all Cold Front? I like OE upgrades.
    2010 S4 Avant, Forged bimotos, Brembos, Revo GB tune
    Veteran Member Four Rings amz's Avatar
    Apr 29 2013
    Ottawa
    Quote Originally Posted by acsgp View Post
    I just had the same thought. Can anyone send pics of a naked B8 radiator vs. B8.5? Hopefully its "plug and play"
    2012 S4 ~ Phantom Black - Mustang Brown - B&O - Sport Diff - DSG
    AWE Touring Exhaust | Roc Euro Intake | Eurocode Alu-Kruez | Eurocode USS Swaybars & Solid End Links
    Canada: the land of Quattro
    Dec 19 2010
    North CA
    It's not the hoses and locations are different. It's also probably just as expensive.
    Jun 12 2015
    CA
    Perhaps when stock.
    The aftermarket products don't replace the stock units. They work together.
    Lot of good info here...never knew that the supercharger water cooler was that small. Obviously the engine coolant and supercharger coolant is shared in the stock system. So, if I was to upgrade to, say, the revo unit, that just consist of the the larger heat exchanger and an additional coolant tank, the coolant is still shared through the whole system no??
    Jun 14 2015
    FRANCE
    Quote Originally Posted by derek.kritz View Post
    Hello,
    APR, AWE are divorced systems. I think REVO and Forge also.
    Not sure about Alpha.
    BR
    Mat
    Jun 14 2015
    FRANCE
    Quote Originally Posted by amz View Post
    Quote Originally Posted by miztahsparklez View Post
    Quote Originally Posted by Mat@1975 View Post
    Hello,
    BR
    Mat
    I had the same though also, about the add. cooler.
    It seems that a lot of parts are involved, i will rough estimate the cost this week end...
    https://www.partsbase.org/audi/audi-...l-coolant-rad/
    Best regards,
    Mathieu
    Dec 19 2010
    North CA
    I have the PLM exchanger. Probably one of the best mods I have. The car always feels quick, even on a hot day. I wouldn't spend all this time on labor just to get marginal performance.
    Oem might be great in your mind, but OEM has also failed in the cases of rocks going through and puncturing the cooler. The same can happen to the aftermarket ones, so just because it's OEM in this case, doesn't mean it's better.
    Jun 14 2015
    FRANCE
    Hello,
    Took a look on the parts costs.
    A rough estimate is 350-400 € for the major parts of this additionnal cooler (hoses, brackets, cooler,...) excluding clamps, nuts, ...
    Seems a good bang for the bucks ?
    BR
    Mat
    Jul 18 2014
    Singapore
    Best regards,
    Mathieu
    Great, thanks Mathieu
    Best
    Andrew
    The PLM exchanger is definitely in the conversation for me. I have not heard anything but great reviews on it. Do you have the the expansion tank as well? I'd really like to get REVO involved in a group buy. I really like the look of it.
    Dec 19 2010
    North CA
    The PLM exchanger comes with an aluminum tank. I don't think I needed another reservoir to divorce it from the stock cooling system.
    PLM comes with all the hoses and clamps for both b8 and b8.5.
    After doing the work, it's something I'd rather do only once. Don't skimp out on trying to just do OEM. The benefits just aren't there.
    I would say get any of the exchangers you can get for the best price. They will all perform around the same, unless you're into road racing or something, where that fraction might actually matter.
    Cool. I just asked about the expansion tank cause I see that they sell the exchanger with and without the tank. U obviously got the one with the tank.
    Dec 19 2010
    North CA
    I got mine in a deal lol. Didn't know they had another flavor without it.
    Jul 18 2014
    Singapore
    The benefit for me via the OE upgrade route is that the authorities here are pretty anal, and we have to send our cars for semi-annual inspections. One of the reasons why I went for the Q5 3.0T calipers instead of the 6 pot StopTechs with a 355 disc.
    Great, thanks for letting us know your experience. One thing about the PLM system - with the increased coolant capacity, why isn't the pump upgraded.
    Dec 19 2010
    North CA
    PLM is almost identical to another brand. That brand's reasoning was because it didn't actually change the performance much if any. Not sure if it was just a cost cutting measure or if that's really the case.
    Jan 04 2013
    Phoenix, az
    Quote Originally Posted by colby7 View Post
    Yes they do. The aftermarket coolers completely replace the stock supercharger cooler. That is my point. At that point both the B8 and B8.5 have the same primary supercharger cooler but the B8 will have the additional pre cooler that the B8.5 does not have.
    Aug 09 2015
    Sarasota, FL
    out of curiosity, with a divorced system, what type of fluid are you all using for the S/C coolant?
    Jan 04 2013
    Phoenix, az
    I looked at my car for the loop, I do not see it. Specs are in the sig. When I switch between comfort, dynamic and auto I can feel the difference in the steering so I know it changes. Is it in front of the radiator? Perhaps I am just missing it.
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    Quote Originally Posted by Loe View Post
    stock coolant G12
    Since we are on the topic of the heat exchangers, has anyone done a killer chiller yet?
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Jun 14 2015
    FRANCE
    Hello,
    I think you can't miss it.
    If you don't have it, it means you don't have the "dynamic steering" option. However, to have the ADS able to set the steering more or less stiff.
    Dynamic steering is not only able to stiffen the steeiring, but it also changes the "gearing" of the steering. ie, in dynamic, you need less steeering inputs to have the same wheels turning.
    I don't know if it's clear... ;o)
    BR
    Mat
    Veteran Member Four Rings theswoleguy's Avatar
    Dec 07 2012
    Atlanta, GA
    Quote Originally Posted by infinkc View Post
    stock coolant G12
    this with a divorced system would be silly. winter year round
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, E85, Sold
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, Sold
    '15 Audi S4: Stock, S-Tronic, B&O, NAV, ADS w/ Sport Diff, Smart Key, glacier white w/ magma red, 19" Shamrocks lol
    Jan 04 2013
    Phoenix, az
    Hello,
    BR
    Mat
    Makes sense need to look at the build sheet.
    Oct 17 2014
    NorCal
    I just found out my used s4 has GIAC stage 2. I have Intake and Exhaust plus some suspension mods, now that I do not have to spend the money on a tune I wanted to look into cooling mods. I am currently stationed in Great Falls, Montana. So very cold winters and summers in the 90s, I am at 3300'. The issue is that we can get stationed elsewhere whenever the AF decides its time for us to go. I really only do some spirited driving around town and have a 4 min drive to work. I assume I can forgo these mods for now but wanted to look into it. What is the most cost effective route I could go now? HE?
    2019 RS3
    2014 S4 P+
