Results 1 to 6 of 6
    Established Member Two Rings Cameron_'s Avatar
    Sep 08 2015
    2007 BMW 530i
    I need help! Please!
    Okay so I've been looking non stop for the solution to my problem but I can't seem to find a definite answer anywhere I look. I have Niche 19x8.5 wheels, only problem is that they are not flush. My bore (as everybody knows) is 66.6 (66.56) but my wheels are 73.1. Now I have the hub centric rings that go from 73.1 to 66.6, but this is where the problem comes in. I really need/want spacers, but can a hub centric ring work with a spacer? If not what are the other options? Please help!
    Veteran Member Four Rings Audi 4 Life's Avatar
    Jan 16 2011
    06 D3 A8 Black/peanut with alcantara
    Earth
    Yes just make sure you buy quality spacers, cheap ones can cause issues. MTM spacers are good.
    Sent from my SM-G900V using Tapatalk
    RIP - JHM B6 3.0 6MTQ USP Denim Blue/Black w/ Nappa Silver
    Current- B8 A4 2.0t S-Line Stasis Challenge Extreme Edition, Alcantara Headliner, ALA/ACC and 3g+ swap
    D3 A8 4.2 Black/Peanut (Daily)
    Sep 08 2015
    2007 BMW 530i
    Thank you!!
    Dec 01 2011
    don't they also have hub adapters that are also spacers as well? i've seen those before not sure if it's exactly what you need but i believe you can just get those too. it's like a spacer with it's own set of bolts that goes onto the hub, then has the hub ring and another set of bolt holes. but maybe i'm thinking of bolt pattern adapters.
    IG @theshawon
    Veteran Member Four Rings Party_Marty's Avatar
    Nov 02 2015
    Sector 9 Long-board, Rugby Kit
    In the woods
    Yea a good set of spacers will have the same hub on the side that connects to the wheel. I purchased mine from ECS and they work perfect.
    ---------------------------------------------------------- IG: party_martyy ----------------------------------------------------------------------
    ---------------------2014 A4 - 6 Speed - Phantom Black Pearl -------------- Peep the Build ---------------------
    Veteran Member Four Rings adamazing's Avatar
    Apr 26 2014
    San Diego, CA
    You can order custom made spacers (for a little extra $$) that can account for the centerbore difference as well. That would allow you to ditch the rings entirely.
    2013 A4 Quattro Green Black Iridescent / APR E85 Stage 2 / AG F421 Polished Copper / Eurocode FMIC + HFC / AWE Quad + CF Diffuser
    build / instagram / flickr
