Results 1 to 12 of 12
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    [Update] Does your sunroof has four rings on it?
    [Update]
    Looks like all glasses on the car, except sunroof glass, have audi four rings logo on it. The sunroof glass will only have manufacturer name on it.
    Today I found the CPO car I recently bought doesn't have Audi logo on the sunroof, and it says Pilkington on it. Is that the original glass? If not, is that okay to have non OEM glass on a CPO car?
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    I've never noticed the emblem on the glass. Then again, I don't exactly spend a lot of time staring through my glass roof. Where on the glass would it normally be?
    2013 Audi S5 - EPL Stg 2 E40 ECU/TCU, AWE Track 102mm, RocEuro intake, etc.
    2014 Audi Q5 S Line
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Oct 27 2011
    New Jersey/ U.S.
    I believe you are talking about the manufacturer of the glass which is usually located on the lower corner of the glass, driver side. All the glass on my vehicle is Audi OEM. So it is highly likely the glass was replaced. For your other question, as long as the glass meets or exceeds the standards required, then I would not worry about it.
    2024 Ascari Blue RS 5 Sportback
    May 20 2015
    Watertown, MA
    I would not be concerned about it at all.
    Veteran Member Four Rings SLU_S5's Avatar
    Sep 06 2014
    Rochester, NY
    I seem to remember that a lot of the glass in my car says Pilkington on it. I'll have to double check but I'm pretty sure that some panes have the Audi rings in addition. I'm pretty sure Pilkington is the OE glass manufacturer - I doubt Audi makes their own glass.
    2010 S5 Prestige 6MT: B.Black:
    APR: Intake // AWE: Touring + non-res DPs, S-Flo filter // CR-15: Brace // ECS: LWFW, Diff Mounts, SS Brake Lines // Eurocode: AK, Sways // JHM: Tune, Short Shifter // KW: H.A.S. // OEM+: B8.5 S-Line Competition+ Bumper, BO S5 Grille, Ecodes, RS5 BBK, 20" RS5 Rotors// SBC: Stg 2 Daily // 034 Motorsport: Intake Pipe, Trans & Motor Mounts, ACAs // Others...
    IG: @SLU_S5
    Established Member Three Rings miked1978's Avatar
    Oct 27 2015
    Houston, TX
    Quote Originally Posted by SLU_S5 View Post
    I doubt Audi physically makes anything. They commission suppliers to manufacture to specific specifications and then assemble the product.
    to the OP - is it leaking? if not, don't give it another thought.
    Veteran Member Three Rings ParadigmTony's Avatar
    Apr 02 2015
    Rochester NY
    Does it leak and can you see through it? Thats about the only concerns that would matter to me. I suppose a broken sunroof glass would be a perplexing scenario, Id like to know more about if it were mine, but the glass wouldn't bother me. Side Note all the glass in my Range Rover is also from Pilkington, never noticed that before.
    //B8 A5 // 6MT DSB Pearl // Roc-Euro // APR // AWE // BBS // Bridgestone // StopTech // // K04/Stage 3v3/FMIC/Roc-Euro Intake/Test pipe-AWE touring/100oct life/19x10 CI-R/RE71R/ST60 BBK //
    Established Member Two Rings 49Willys's Avatar
    May 22 2015
    Lake Stevens , WA
    All the glass in my A5 is AUDI oem and the sun roof is Pilkington but has the same coding as the other glass. So I would say that is oem and not a replacement
    Mine 15 SQ5 Seapang blue Black optics
    Hers 08 A4 S-line Ti 3.2 trip
    Gone
    06 S4 25 Quattro(oil consumption)
    08 A5 S line 3.2 mt total loss water damage
    Sep 06 2014
    Rochester, NY
    Just checked - my windshield and sunroof do not have rings and say Pilkington. Side windows have rings.
    IG: @SLU_S5
    Jan 09 2016
    Quote Originally Posted by 49Willys View Post
    Thanks! All my other glasses have audi logo on it. That's why I was confused.
    2013 S5 Misano Red, DSG, B&O, Sport Diff, MMI+, JHM 207mm crank pulley (7PK1370 Contitech belt), APR Stage II Dual Pulley, APR TCU tune, APR CPS, CR15, IE CAI
    2018 XC90 Inscription, B&W sound, Convenience Pkg, Air suspension
    2014 Mercedes E350 rwd
    2021 BMW 540i
    Jan 09 2016
    Yeah, my side windows and windshield and back window all have audi logo on it, they are come from different manufacturer however. Thanks for checking!
    2021 BMW 540i
    Jan 09 2016
    Quote Originally Posted by HazeMyth View Post
    It's at the rear center section.
    2021 BMW 540i
