Results 1 to 4 of 4
    Nov 19 2012
    Irvine, CA
    RS5 Ceramic Brake Pads
    Hello Audizine folks.
    I just found out that my front brake pads aren't OEM. I have Carbon Ceramic Rotors and I don't think I am stopping properly. The previous owner did a 250 dollar brake job on the car which doesn't match the price of the price of Carbon Ceramic pads. I brought the car to the dealer numerous times about this issue and they never said there was anything wrong with the brakes....
    Opinion and suggestions on issue are welcome.
    Thank You
    Current Vehicle:
    2013 Audi RS5
    Daytona Grey | Carbon Ceramic Brakes | Bilstein PSS10 Coilover | Custom Sport Exhaust | Eurocode Sway Bars Eurocode End Links | LYKT Sport Control Arms
    Sponsors: Bilstein US | Eurocode
    Past Vehicle:
    2014 Audi A5 S-Line Ibis White
    2008 Audi TT V6 Ibis White
    Jan 18 2015
    Are you having issues not getting enough braking force/power? Carbon brakes work best by generating heat. With standard brake pads I think you're likely not generating enough heat to get the system grabbing hard. You might also expect to see accelerated pad wear; I think the carbon rotors are likely much more abrasive than a standard iron rotor. Not sure if your rotor is now "contaminated" because it's got standard pad material on it. I don't think you can turn a ceramic rotor the way you do irons.
    Nov 19 2012
    Irvine, CA
    Quote Originally Posted by Rocket Tech View Post
    From the Ferrari forums, it seem you can deglaze the rotor with heavy braking. I am having issue getting braking power, I feel like it should stop quicker.
    Current Vehicle:
    2013 Audi RS5
    Past Vehicle:
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    You definitely need to check you have the correct pads installed!
    CCBs feel like normal brakes from cold, if anything they are a little less grabby than the iron brakes, when they get some heat in them they come alive, you absolutely do not feel that the car should stop quicker or that there isn't enough power.
    Once you've confirmed the pads are correct or you've had the correct pads installed, do the bedding in process for new CCBs - serveral runs with increasing speed, starting with average braking force, increasing to hard braking (do not let the abs cut in). Allow the brakes to cool off between each run.
