Results 1 to 4 of 4
Thread: DSG and Dynos
    Established Member Two Rings SilverRings's Avatar
    Aug 20 2015
    Louisville, KY
    DSG and Dynos
    So, the DSG has a kick down switch at WOT. How do you avoid this in a dyno pull? What rpm can you take the car to, then floor it and not have the kick down engauged. Just wondering how everyone handles that.
    Oct 03 2015
    Suisun City, CA
    Go TO the kickdown until 5k. Then, you should be able to go past. Either way, you don't really have to go past the kickdown.
    Veteran Member Four Rings jran76's Avatar
    Jun 20 2011
    2002 Audi S4
    Plano, TX
    You can go WOT without engaging the kickdown. Basically, any accelerator position over 80% is WOT, and the kickdown is not engaged until after that. It just takes some finesse and getting use to to find the sweet spot.
    If you can log with VCDS while doing it, it's real easy to see.
    2018 S4 : Daytona Gray : Black Nappa : Carbon Atlas : S Sport : Black Optics : 034 Springs/Rear Sway Bar/Inserts : 19x9.5" BBS CH-R Wheels : EPL tune : Wagner Intercooler
    2002 S4 : Black : Black Leather : 6-Speed : Stage 2+ ...
    2022 Q7 : Mythios Black
    Stage 2 Banner Advertiser Four Rings
    Sep 06 2007
    Quote Originally Posted by jran76 View Post
    Correct. We tested this as well by shutting off the kick down switch for dyno purposed and found identical results.
