Results 1 to 3 of 3
    Senior Member Two Rings Lizard 1's Avatar
    Jan 26 2016
    Lots of fun stuff
    Gahanna, OH
    Corsa fitment for 4.2 on the downpipes...
    Got a new Corsa system for my 2012 S5 4.2 V8. When I go to mount the down tubes, driver's side is WAY off. I mean like it needs rotated for it to come close and therefore will not align with the flange coming from the car. The passenger side does work. It does seem a little close to the under carriage but would work due to the flex mesh stuff.
    Anyone have this issue? For the cost of these systems, I would suspect that they are using a jig and really shouldn't be able to mess it up.
    Now, is it possible that the flanges will be able to be rotated once bolted and I try and turn the pipe? I suspect that the mesh top and bottom are welded and wouldn't be able to, but never know.
    Really bummed I got the car up, took everything off and nothing fit. Sitting on stands and can't obviously be driven unless I install the stock system which is going to have do be done since it is my daily.
    Just looking to see options if there was a trick, etc... I can post pics for reference... Just shocked really... Thought it would be better quality. The X-Pipe also didn't want to go on to the back section piping and had to bend the cross plate that was welded on the resognator section to mesh up.
    Veteran Member Four Rings Sgibb16's Avatar
    Jul 02 2012
    2012 A5 & 2002 Passat Wagon
    Fredericksburg, VA
    Quote Originally Posted by Lizard 1 View Post
    Did they send you 2 passenger sides by mistake?
    2012 A5 P+ | Sports Package | 6MT | 35% Tint
    REVO Stage II | AWE Quad Exhaust | 034 HFC | E-Codes | FK Silverline Coils | JHM Short Throw Shifter | Eurocode HFIC Pipe | Roc Euro Intake
    TR8 Intercooler | CTS Silicone Hose Kit & Turbo Outlet | CR-15 Strut Brace | Alu Kreuz | S-line Front & Rear Bumper Conversion
    Jan 26 2016
    Lots of fun stuff
    Gahanna, OH
    No. The part numbers are 10A14069 and 10A14065 and both are very different. Both would technically fit the passenger side actually, though. The issue is that I don't know what fits on the driver's side and therefore really cannot tell which is the one that should be the passenger side.
