So for a while now I has problems with the car stalling out of no where after it idles for a long time. I had changed out all the cam sensors and solved my problem for a good 2 months. I kept being told it might be the tensioners on their way out due to the start up rattle noise. This past week the car takes longer to start and today it started turning off before I left for work. I bright home my snap on scanner and pulled these codes out. Keep in mind my car is high mileage, do you guys think I should go ahead and tackle the tensioner job for both sides or what do you think could also be causing this
