Results 1 to 6 of 6
    Oct 07 2013
    Bellevue WA
    Difficulty engaging first gear when engine/transmission is cold.
    This is an annoyance more than anything but I find its extremely difficult to engage first gear in my RS4 when the engine and transmission are both cold. After driving for a few minutes and the oil temperature increases, the issue appears to ease and there's no longer a problem. Is this normal/expected? Can anything be done to alleviate the issue eg transmission oil change?
    Veteran Member Four Rings badbluers4's Avatar
    Oct 27 2011
    Atlanta, GA
    Try changing fluid to redline or Motul and give that a try. Also make sure you use other gears to try and engage synchros and then go back to first.
    Oct 07 2013
    Bellevue WA
    Quote Originally Posted by badbluers4 View Post
    OK, will try this and see if it helps.
    Veteran Member Four Rings your daddy's Avatar
    May 29 2007
    NOW-17 R8 V10+,08 RS4/Ti/AE,2021 S6, THEN-08 ibis TI,02 337, 01 S4, 92 gti vr6,90 corrado, +many
    Billerica/Lexington,MA
    also, before shifting into either 1st, or reverse, shift into 3rd first. also, the motul gear 300 should help.
    Rick autoengineering.com @autoengineeringlexington
    -APR-Integrated Engineering-JH Motorsports-034 Motorsport-ECS tuning-Forgeline-CTS, plus many more
    Account Terminated Four Rings
    Dec 03 2009
    PNW, Washington
    I haven't had any issues with my RS4, however my s4's transmission hated life when it was chilly out. Usually 3rd->2nd->1st helped it go in easier. Might just need a fluid change.
    Oct 07 2013
    Bellevue WA
    Quote Originally Posted by Peter1.8t View Post
    My 2006 B7 S4 had no such issues, hence why I'm surprised to come across it in the RS4. Anyway, I will get the transmission fluid changed the next time I have a few hours to spare and can take it into the shop (I don't have the means or time to do it myself as much as I'd like to).
