Results 1 to 3 of 3
    Established Member Two Rings Ego_Trip's Avatar
    Apr 01 2014
    Utah
    Removing CG Jet Seal, help?
    So I haven't been able to find a clear answer. Not too long ago I had my car sealed using Chemical Guys Jet Seal. However, now that it's warmed up I have a scratch I'd like to fill, and a trunk spoiler I'd like to stick on.
    What is the safest (to my paint) way to remove the jet seal from that certain area so the adhesive tape will stick?
    [2011 Audi A4 2.0T Prem. + Quattro]
    Veteran Member Three Rings Avus RS4's Avatar
    Apr 09 2015
    Niwot, Colorado
    Quote Originally Posted by Ego_Trip View Post
    Try some ISO 50-50
    That is Isopropyl Alcohol diluted with water mix
    Or rubbing alcohol diluted
    2007 Avus Silver Rs4
    Bone Stock
    Jan 18 2015
    I believe chemical guys citrus wash and gloss cut at 1oz/1 gal will strip your lsp. I havent tried this but if you've got that soap worth a shot. I can confirm I recently stripped wax/jet seal using their hard water spot remover (this one: http://www.autogeek.net/chemical-guy...iqUBoCIF3w_wcB). It's acid based; I applied it full strength via a microfiber sponge pad. Easy wipe on, give it a few seconds, then neutralize using Eco wash and followed up with a distilled water rinse. I didn't want to do the whole car, just a small panel.
