Results 1 to 6 of 6
    Established Member Two Rings 99r6's Avatar
    Dec 03 2015
    Wichita
    Radio turns on without key?
    I've had this happen to me 3 times already.. As I shut the ignition off, take the key out, open the door and get ready to exit.. the radio turns back on. Am I doing something funky or is my car possessed?
    2011 A4 B8, 1985 E30 (M50 Turbo), 2002 Ram 1500 (Lifted + 35"s), 2015 Grom
    Established Member Two Rings zxg01's Avatar
    Sep 23 2010
    1993 RX7 (1JZ swap in work)
    Quote Originally Posted by 99r6 View Post
    its possessed! get rid of it asap, by get rid of i mean give it to me for a cheap price, by cheap price i mean free.
    Veteran Member Four Rings Elliott's Avatar
    Oct 28 2007
    Ocean Beach, CA
    Quote Originally Posted by zxg01 View Post
    CEO and General Manager of the AZ Pedal Responce Team
    Established Member Two Rings Iridium.'s Avatar
    Nov 07 2012
    Okanagan Valley
    Maybe an issue with the door switch or comfort/convenience module issue? Do you have advanced key?
    Dec 12 2014
    Bolingbrook/Illinois
    I think you can operate the radio with the car off depending on what buttons you press. maybe you just accidentally pressed one?
    2012 A4 P+ quattro S-line appearance
    Senior Member Three Rings B7AudiSline's Avatar
    Jul 14 2012
    Eastern Shore,MD
    I think the radio works up to 10 mins after turning off the engine if you hit one of the MMI buttons.
    2012 B8 Quattro Prestige S-line/Black Optic PKG/Phantom Black Pearl/VCDS/TINTS/APR HFC W/3inch downpipe/Kohlefaser Luft-Technik Intake System/Turbo inlet hose/APR Stg 2/R8 Coil Packs/
    Luft-Technik Intercooler w/hard pipes
    RIP 2007 BB A4 2.0T Quattro Tip S-line Titanium Pgk/APR STG 2/Test Pipe/3'' Downpipe/Forge DV/K&N Drop in Filter/VAGCOM/APR Snub Mount/ECS Vent Pod Boost Gauge/CC/HOEN Fogs/LED City Lights/ECS LED Plate Lights/Tint/RIP
