Results 1 to 31 of 31
    Senior Member Two Rings Muggerrudd's Avatar
    Apr 01 2014
    Cleveland Ohio
    Question: Best exhaust under $1000
    my exhaust is in need of replacing. What can you suggest for under $1000.
    Cat back or Turbo back. I am willing to purchase either a HFC or TP separate.
    2007 2.0t quattro w/trip trans
    2007 A4 2.0T QUATTRO
    Veteran Member Four Rings Denio24's Avatar
    Jan 24 2013
    Chicago
    I would try to find a shop that would budget your needs. Y pipe to 2.5" and 3" tp and dp would be the way to go if i had time to fabricate. I went with the europaparts cat back and 034 tp
    Sent from my SM-G920P using Tapatalk
    Garage: 2008 Quartz Gray Audi A4Q 6MT
    Tuning: JHM Tuned Stage 2 93 Octane w/ IE HPFP
    Jun 17 2013
    jersey city nj
    Veteran Member Four Rings james12lucy's Avatar
    Jul 04 2015
    North America's only B7 Chump Car. 2006 2.0T A4, fully gutted, custom Loose Stones Racing Roll Cage,
    Toronto Ontario
    Buy a used JHM/FI cat-back and bite the bullet on a new JHM y-pipe. You can likely get it for around $1200 and you likely won't find anything g better.
    B7 Avant, 6MT, Quattro - Brilliant Black: JHM 93 Octane Stage 2 tune, APR HPFP, S3 Injectors, JHM Test Pipe, Stasis Catback, R8 coils, 034 TIP, Custom CIA, 18" VMR 710, Podi Digital Boost Gauge, RS4 rear sway bar, RS4 grill, Eurojet Billet VC, 42DD catch can, Ohlins SL Coilovers w/ Hyperco springs, OEM Bi-Xenon retrofit, GFB DV+, Brembo 18z.
    Established Member Two Rings shahk62's Avatar
    Jul 14 2015
    Sydney
    Quote Originally Posted by Muggerrudd View Post
    Buy the jhm HFC and dp (necked down to stock size) and then buy a used B6 S4 catback exhaust (even OEM). All up should be less than $1000 USD
    2005.5 B7 A4 2.0T Quattro - 034 RSB + End links, GFB DV+, 034 Snub, 034 Billet Rear Diff Carrier Mounts, BSR CAI
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Quote Originally Posted by Denio24 View Post
    Yes. Custom all the way.
    Veteran Member Four Rings Copen-cisco's Avatar
    Sep 06 2013
    B7 Audi A4 Avant+ B7 Sedan and '69 912
    Dublin, CA
    How much do a custom exhaust setup usually run at? Compared to for example Europaparts bolt on system?
    I picked up a used Milltek cat back system for $400 and super happy with it.
    Kristian
    l Audi A4 2007 Avant l 2.0T TIP l Custom Stage 2 tune l IE HPFP l 034 HFC l 034 TIP l Rev Snub mount l 034 motor mounts l ST Coilovers l RS4 rear sway bar l Milltek Cat-back Resonated l S4 Recaro l RNS-E MKII l 19" Peelers
    Apr 12 2015
    '06 VW TOUAREG (V8), MTN Bike
    FALLON, NV
    Quote Originally Posted by shahk62 View Post
    This! But got a TP instead. New JHM TP-DP, $700 plus used B6 S4 CB for $60. And installed them myself.
    I'M THE ORIGINAL OWNER OF '07 B7 A4 2.0T 6MT Q (62K): JHM 91 OCT STG 2 | CARBONIO INTAKE | 034 REAR SB | JHM TP | JHM DP-Y | B6 S4 CB
    Veteran Member Four Rings derrek's Avatar
    Jul 23 2010
    arizona
    I never really liked the idea of using the s4 rear section. With turbo cars you want the least amount of back pressure after the turbo but with a NA car you want back pressure to make tq. Then you go and put a exhaust for a NA car on that's meant to have back pressure, doesn't make sense.
    Not sure where people got that custom was cheaper? The materials alone for my exhaust were more then half of what most sell for and then add about 12hours of labor it took to fabricate it. Sure you can get some muffler shop to make one cheap but it will never be the same quality as most of the pre made ones for our cars.
    Nov 15 2011
    Montreal | I sell in USD
    ^^ pretty sure the S4 dp back flows more than an oem A4 dp back. 2 x 2.25 > 2 x ~1.75 and I really doubt the mufflers are made to create back pressure.
    I went that way because I wanted more flow, an oem exhaust (because we can het a ticket here for non-orm) and no drone/loud exhaust.
    *****I sell in USD*****
    Apr 12 2015
    FALLON, NV
    Quote Originally Posted by Axis View Post
    This.
    If the flow is enough for an S4, it should be plenty enough for a tuned A4. Plus $60 is < $1100!!!
    And no drone/loud exhaust...
    For now, I'm satisfied...
    Jul 23 2010
    arizona
    Quote Originally Posted by MISKIE View Post
    This.
    sure it flows more then stock, stock is almost as thin as a toothpick but S4 exhaust vs quality aftermarket the aftermarket exhaust is going to flow way better. Click the link below if you want to learn more about NA exhaust and back pressure. for turbo cars the best exhaust is no exhaust, you want as little restriction after the turbo as possible, that's not always ideal though. funny thing about drone is besides 100% stock exhaust system i had the least amount of drone when i was straight piped, it didnt sound the greatest and was too loud but had the least amount of drone out of the 4-5 exhaust setups ive built. If i had to buy an aftermarket exhaust I'd probably go with the stasis/EuropaParts exhaust its cheap and sounds the best IMO.
    https://www.google.com/search?q=back...utf-8&oe=utf-8
    Stage 2 Banner Advertiser Four Rings Hugh@EuropaParts's Avatar
    Aug 22 2010
    Piscataway, NJ
    I'm pretty sure our system is the best bang for the buck and you'll be well under $1,000.00. Between STaSIS and our system they are hands down the most popular choice as we have literally sold hundreds. They are in stock and ship the same day.
    PERFORMANCE EXHAUST SYSTEM (A4 B7 2.0T QUATTRO, MANUAL) $899.99 SHIPPED
    PERFORMANCE EXHAUST SYSTEM (A4 B7 2.0T QUATTRO, TIPTRONIC) $879.99 SHIPPED
    • Power increase will be in the 10 - 15 TQ/HP range.
    • An aggressive yet drone free tone will give your vehicle a sporty sound which is sure to turn heads when you press the pedal to the metal.
    • Mandrel bent T-304 stainless steel.
    • Laser engraved Europaparts logo.
    • Note: The tiptronic exhaust system does not include a downpipe.
    Hugh
    EuropaParts.com, Your Trusted Audi Parts Source
    Facebook: Like Us on Facebook
    Instagram: Follow Us on Instagram
    Nov 15 2011
    ^^This with an hfc/test pipe is probably the best cost effective vs quality route.
    Quote Originally Posted by derrek View Post
    As I mentionned above, I went oem S4 dp back because of the police in my area... I previously had an aftermarket (custom). If you're curious click here : Clicky click
    I was just mentionning the oem S4 dp back will flow better than an oem A4 even if they have crush bends. For someone on a budget, or someone who wants more flow but not more noise, its a great alternative.
    Aug 22 2010
    Piscataway, NJ
    ^^I would say about 75% of all the exhausts we sold were mated with an 034 HFC.
    Hugh
    Nov 15 2011
    Hfc's give a deeper tone and it doesnt give you that Skidoo smell at red lights. For the little gain a test pipe will give, I dont see the benefit. But to each their own hence why I said hfc/test pipe :)
    From your picture it seems the flex pipe sits higher on the dp which is the another plus
    Veteran Member Four Rings oVeRdOsE's Avatar
    Jul 01 2015
    Mtl
    http://www.ctsturbo.com/cart/product...K-4648-99.html
    wait for this one to come on sale. Few months ago it was around 700-800, can't remember.
    Senior Member Two Rings Yogie's Avatar
    Jul 30 2013
    05' WK Jeep 5.7l Hemi
    So Cal
    I like that "skiddo" smell at red lights.
    I +1 on the stasis being cheapest and best bang for your buck.
    '2008 Brilliant Black A4 Avant S-line/Ti 6Speed Quattro'
    Jun 27 2011
    This. People serious up don't quite get that. Plus you're just guessing at what muffler designs are going to sound best with our engine and how much drone you're going to have.
    An off the shelf system is almost always going to be a better bet unless you have some crazy setup or want something super custom.
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Jul 01 2015
    Mtl
    fluid dynamics.
    Same for intakes, NA with ported intakes can help , but if it's too big you'll decrease air speed, so the power. air flow and air speed are important on NA engines since you only have around 14.6 psi .
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by Yogie View Post
    +1 maybe I enjoy a free when the windows are all rolled down
    Nov 15 2011
    Quote Originally Posted by vce1232000 View Post
    vce = Testpipe ambassador lol
    Aug 31 2011
    C7 A6 3.0T Prestige - AEV JKUR
    Lathrop
    Thanks for the support guys!
    We ran a 12.5 with a stock S4 system mated with our downpipe-Y and test pipe. If you are on a budget and/or looking for an OEM + style exhaust system you really can't beat it because the performance is there and you get a bump in sound.
    See the end of the video for the 12.5 run with stock s4 cat back.
    https://jhmotorsports.com/shop/catal...0t-p-2588.html
    Test Pipe: https://jhmotorsports.com/shop/catal...0t-p-1852.html
    HFC: https://jhmotorsports.com/shop/catal...0t-p-1893.html
    Downpipe-Y 6mt/CVT: https://jhmotorsports.com/shop/catal...vt-p-1946.html
    Downpipe-Y Tip: https://jhmotorsports.com/shop/catal...ip-p-2190.html
    JHM/FI B6 Cat back: https://jhmotorsports.com/shop/catal...-fi-p-384.html
    JHM/FI B7 Cat back: https://jhmotorsports.com/shop/catal...-fi-p-385.html
    Apr 01 2014
    Cleveland Ohio
    Quote Originally Posted by Hugh@EuropaParts View Post
    What test pipe / high flow cat works with this for a quattro triptronic?
    Aug 01 2014
    Ohio
    034 fits up with it!
    Feb 18 2015
    United States
    +1 on the europa parts exhaust. good company to work with, great quality, good sound. For $900 you have a full exhaust with a downpipe. I am looking to go this route very soon
    Veteran Member Four Rings PDX04a4's Avatar
    Jun 22 2008
    2006 A4 Avant S-line
    SL,UT
    Quote Originally Posted by FellowM3 View Post
    Not for tiptronic, it does not come with a downpipe. As far as I know the only downpipe for tiptronic that hasn't had a ton of issues is the jhm, but of course if you go with the jhm you either have to modify it to work with the exhaust from europa or buy an s4 exhaust.
    Thanks for the EFF shack. -Dirty Mike and the Boyz
    Jun 27 2011
    Quote Originally Posted by PDX04a4 View Post
    Nobody cares about the tip!
    Also I've not heard of any issues with the TT downpipe I don't think. Brett had zero issues with his on his b6 which is pretty damn similar fitment.
    -CP
    2017 Q7 3.0t
    Registered User Four Rings Sales@DriveAuto's Avatar
    Apr 13 2012
    Clifton/Mountainside, NJ
    I have a brand new Milltek resonated catback sitting here - I'd have to ship it, but I can probably make the numbers work for you. Great quality, great sound - can't go wrong.
    Veteran Member Four Rings LoKisSpYdR's Avatar
    Jun 26 2012
    Brilliant Red B7 A4 2.0T Titanium quattro Tip - 2015 Q7 PP
    Reading, PA Area
    I also have the TT DP for ~30k and haven't had a single problem with it.
    B6 A4 1.8T Dolphin Gray qM
    4L Q7 3.0T Glacier White PP
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by LoKisSpYdR View Post
    The only issue was mine was I blew out the flex pipe. I bought it to a exhaust shop and they a new one on and been ing great ever since
