Results 1 to 4 of 4
    Established Member Two Rings kshup2me's Avatar
    Feb 06 2012
    Toront , Ont
    Question Drive Select question for you experts!!1
    Hey guys,
    Just bought a 2013 A5 S-line. Pretty excited about it but when i was test driving in noticed that "drive select" has three functions, maybe because the dealer was talking my ear off i was not paying attention but did not seem to notice a difference. Is this something that has to be activated A) when first bought ( i am the second owner) or B) through MMI?
    have read several posts and still not quite clear. would really appreciate some info on this !!!
    Kevin
    Established Member Two Rings CVTwhatadumidea's Avatar
    Jul 16 2008
    2010 MB C300 4Matic Sport
    Fort Wayne
    Quote Originally Posted by kshup2me View Post
    Hey guys,
    Kevin
    Drive select will offer you up to 4 profiles; Comfort, auto, dynamic, and individual.
    Comfort sets the vehicle to lighter steering, and less throttle response
    Auto adjusts based on driving conditions
    Dynamic gives you heavier steering, and most aggressive throttle response
    Individual allows you to set steering and throttle individually to either: comfort, auto, or dynamic.
    You may also have correlating suspension settings if your vehicle is so equipped.
    QGM '08 B7 2.0T 6MT Premium+ | APR Stage 2+ | Podi Mechanical Boost Gauge | RAI HFC/DP combo | APR HPFP | ECS snub mount | JHM chromoly lwfw and RS4 clutch | LaPower Bluetooth Module | Black Headliner Conversion | Pipercross Dry filter | R8 Coils | GFB DV+ |
    Established Member Three Rings miked1978's Avatar
    Oct 27 2015
    Houston, TX
    watch your tach and see if your cruising rpm's and shift points change for starters. you should feel suspension and steering stiffen up on dynamic too unless your PO changed the damps.
    Feb 06 2012
    Toront , Ont
    thanks guys
    appreciate the info.. Just been reading how it has to be activated in MMI etc or that some have options that have to be purchased.. I was not sure if it was just a setting without any actual function. would have been very disappointing.
