Results 1 to 4 of 4
    Junior Member Two Rings
    Oct 11 2015
    Blue Bell, PA
    Front driver noise
    Hey guys,
    I did a search but couldn't find any results. I had the KW HAS kit and adjustable control arms installed on my Q5. There has been a faint click sound coming from the driver front when I go over bumps. Kinda sounds like two plastic pieces tapping against each other. I'm guessing it has to do w the set up but wanted to see exactly what it was and if I could fix he noise. Thanks for the help in advance.
    Rog
    Oct 11 2015
    Blue Bell, PA
    Bump.
    Anyone w KW HAS and stock shocks experience this knocking sound?
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    pretty sure in my experience with coilovers / suspension in general, this means the top nut is loose and the spring is shifting slightly. in some products the spring shifts slightly anyways b/c there is no defined seat point for it. i wouldn't worry about it
    I have Adjustable Control Arms along with Coilovers, and they do make some noise when turning the wheel, especially at full lock. I've understood this as being normal.
    His: #samoas3 | 2016 S3 | P+ | Audi Exclusive Samoa Orange | GIAC Stage 2 + TCU | Neuspeed | 034Motorsport | CTS Turbo | HG-Motorsport | Neuspeed RSe102 19x9 et40 *138.8 MPH Half-Mile*
    Hers: #lavasq5 | 2014 SQ5 | P+ | Lava Gray Pearl | AWE/GIAC Stage 2 | KW | SPC | 034Motorsport | AWE | RS Grille | 285/30ZR22 on DPE CS5S 22x10 et22/26
