Results 1 to 19 of 19
    Feb 07 2008
    The boonies, near Seattle
    Fuse 29 & Fuse 32 not getting power.
    This is for the 2.7 swap in to my s6. Rewired body plugs on engine harness to s6 connectors and was simple enough, however, I'm not getting power at either fuse 29 or fuse 32, both of which are labeled engine control unit. My ecu is not getting power on pin 3 (black/blue) but is getting power at pin 62 (pin 21 has no wire in it so I assume it's not necessary).
    I talked to mr. rictus who had the same issue with his swap, but he didn't do the wiring unfortunately :(
    My first instinct says to cut the feed side of these two fuses and run them to the lugs under the dash. Anyone see any problems with this? This way they would still have their appropriate fusing, but just use an alternative power source.
    Thanks.
    -dre
    Veteran Member Four Rings PaperToast's Avatar
    Apr 29 2009
    Quadzilla
    Longmont, CO
    when in doubt, macgyver it
    Rockin' the Rockies
    '01 allroad, 250k woot woot, still boosting on original turbos and tippy, slightly modified. . .
    Scotty@Advanced, "Push it off a cliff, when it hits the ground you should have a few thousand horsepower available for a brief second."
    Sep 11 2009
    NE
    That would work I think. Do you have electric diagrams/shop manuals to trace the circuits? stratocu510 on QW can hook you up with that.
    Feb 07 2008
    I have a Bentley, but can't seem to find mention of those fuses anywhere.
    -dre
    Sep 11 2009
    NE
    Bentley is not factory manual . Bentley is worse than Cliff Notes of automotive world. The 01e service manual itself is thicker than whole bentley which has about 20 pages about transmission.
    Feb 07 2008
    Perfect. Guess I'll go try and track him down.
    -dre
    I went to high school with the guy (Greg aka Swoops) that did Mr. Rictus's swap/wiring/exhaust/etc. and dated his cousin back then, I could probably get you guys in touch, let me know.
    Feb 07 2008
    I sent swoops an email last night. Hoping he'll get back to me.
    After looking at the factory diagram a little bit, I don't see any issues with re sourcing the fuse feeds. Need to read them a bit more when I get home from work.
    -dre
    Just spoke with him, he said he's swamped at the shop and is looking for the wiring diagrams he made during Nick's swap, and he's gonna try and email u back later. Good luck.
    Dec 16 2014
    Irvine, CA
    Which year ECU / Harness are you using for the engine? Into a 2002-2003 S6?
    Feb 07 2008
    Quote Originally Posted by Kaane View Post
    2000 a6 manual engine harness. 2002 s6 car.
    -dre
    Dec 16 2014
    Irvine, CA
    On the 2002 Engine the power to pin 3 is supplied by the J271 ECU Relay. Which is actually controlled by the ECU itself. The 2000 Engine does not have that relay at all. So you will need to bypass it.
    Dec 16 2014
    Irvine, CA
    Dec 16 2014
    Irvine, CA
    Looks like J271 Relay feeds Pin Connector T17i/16 white connector. Input to the J271 Relay is T10p/4 Black Connector which also feeds Pin 62 on the ECM. So make a bridge between those 2 pins and you should get power to fuse 29.
    Feb 07 2008
    Now that makes sense. I had pulled the j271 relay and noticed nothing seemed to trigger it. Google showed it as a relay for power fold mirrors, but the fsm I got today showed it as power for the ecm. So presumably making that relay trigger will fix one of my fuses. Perfect. Thanks.
    -dre
    Oct 29 2005
    10speed
    San Francisco, CA
    Do you have Elsa for the S6 fan specific section?
    - Clint
    Dec 16 2014
    Irvine, CA
    Engine cooling fan? The engine diagrams i posted have a cooling fan section.
    Feb 07 2008
    Well. Got those fuses sorted.
    Jumped black connector pin 4 to white connector pin 16 to get fuse 29 going. Had to repin appropriate gauge wiring.
    Got fuse 32 going by cutting the feed and temporarily running it to 75x.
    Soooo.....
    Now I have power at the ecu but it will not read through vag com and will not illuminate the cel.
    Pins 3 and 62 both have 12v, pins 1 & 2 both have ground. Pin 43 at ecu, green black, k-line, shows continuity with green/red obd pin 7. Vag com works with other equipment in the car, but can't communicate with the ecu.
    I'm stumped, and frustrated.
    -dre
    Aug 31 2014
    2002 stage 3 a6 6MT 2004 cavalier
    Charlotte/Roanoke
    I JUST and I mean JUST got my car running after doing the same (sort of) thing . Ive got an 02 A6 and swapped in a 00 A6 with the harness and all. I had to rewire the White and Red connectors but the others were fine. I didn't, however have an issue with the ECU not getting power. I don't have a wire at pin 21 either. My issue was with a red /grey wire I still have yet to find it's location and a black and violet wire from the red connector. I chased the diagrams for hours via All Data. Good luck with your swap
