Results 1 to 40 of 70
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    1998 yellow 2.8 30V part out, or whole car
    1998 2.8 30V FrontTrak with a manual transmission. Car is brilliant yellow and has 155,xxx miles on it.
    Make an offer on the whole car, or just buy some parts.
    Everything is OBO
    Located in central florida.
    Engine and driveline:
    complete engine-$600
    both heads-$450
    manual transmission-$150
    manual 2.8 ECU-$40
    stock flywheel resurfaced,new sachs pressure plate, and new sachs clutch-$250
    shifter box/shift linkage-$150
    radiator support-$130
    radiator-$100
    altenator-$50
    AC compressor-$100
    AC condenser-$95
    pedal assembly-$75
    crank pulley/engine dampener-$65
    P/S pulley-$25
    stock airbox-$55
    crank/flywheel/engine speed sensor-$25
    condensor fan (in front of radiator)-$55
    electric fan in core support-$45
    coolant tank-$20
    PS tank-$20
    ABS tank-$15
    vacuum canister under DS fender-$20
    washer fluid tank-$40
    bumper squirter pump-$20
    windshield squirter pumped-$20
    suction pump under DS rear wheel well with filter-$35
    charcoal canister box under spare wheel tub-$50
    manual Front Axles(needs new boots)-$50
    Exterior:
    hood-$75
    front bumper-$75
    rear bumper-$75
    complete doors w/o inside panels-$100 each
    trunk-$100
    fenders $75
    gas cap-$10
    gas cover-$20
    ecu box upper-$15 shipped
    cabin air filter assembly 3 piece-$20
    wiper blade metal arms-$20
    trunk hinges-$25
    trunk shocks-$20
    hood strut/shock-$20
    front or rear bumper shock-$45 a pair
    PS cooler loop assembly-$35
    front hood hinges-$25
    rear bumper side mounts-$25 for the pair
    front bumper mounts-$25 for the pair
    horns-$20 for the pair
    rear door black shiny metal triangle pieces in doors-$15 each
    door strikers, latches-$40 set of 4
    door hinge set-$45
    door bear claw latch (mounts in the door)-$25 shipped each
    wiper motor-$40
    wiper linkage-$50
    trunk seal-$20
    hood seal on core support or firewall (rubber)-$20
    tail lights-$60
    tail Light Trim-$30
    Interior/Electrical:
    abs pump 8e0 614 111r-$75
    airbag module 8d0 959 655m-$40
    sunroof assembly-$100
    central locking pump-$75
    gauge cluster(155,xxx)-$100
    steering column-$125
    steering wheel w/airbag-$125
    clockspring-$45
    dash-$100
    e brake-$30
    HVAC-$65
    blower motor-$50
    heater core-$50
    fan control unit module-$45 shipped
    oh **** handles-$20
    complete(F&R) black seat belt set-$70
    6 piece brushed aluminum trim set-$200
    Pass side airbag-$40
    low pair of kick panels black-$30
    lower dash DS knee bolster-$40
    complete glove box-$45
    glove box strut-$15
    dash vents (sides)-$15 each
    fuse panel cover DS-$15
    fuse panel cover PS-$15
    miscelaneous relays-$10 each
    aluminum support under dash-$55
    CD changer-$50
    interior trunk carpeted sides-$15 each
    interior trunk floor carpet-$35
    trunk spare tire hold down-$10
    rear plastic trunk cover on back of trunk going the width of it-$50
    cubby hole side tray in trunk-$15
    carpeted side interior light-$10
    dead pedal-$15
    fuel pump black cover-$10
    fuel pump blue in/out cover-$10
    fuel fump screw on cover ring-$10
    hood latch (on rad support)-$35
    hood latch release cable and pull-$20
    Suspension/Brakes/Wheels/Tires:
    power steering rack-$160
    rear subframe-$60
    front subframe-$60
    brake master cylinder-$60
    brake booster-$60
    spare tire donut-$25
    will get pics up soon. need pics of something sooner, or you dont see the part you are looking for, just ask.
    thanks for looking
    Link to my master FS thread
    http://www.audizine.com/forum/showth...formance-parts
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Dec 13 2010
    FL
    Happy new year!!!
    offers?
    Jul 03 2017
    Ca
    you have the center console trim?
    Dec 13 2010
    FL
    Quote Originally Posted by @BlackPearl View Post
    Not sure what trim you are talking about. Preface doesnt have console trim, it just the console and shift boot.
    Got a pic or PN?
    Dec 13 2010
    FL
    $45 plus shipping.
    Jul 03 2017
    Ca
    what color is your interior?
    Dec 13 2010
    FL
    It's black. LMK what you want pics of, I'll snap them tomorrow.
    Dec 13 2010
    FL
    Center console
    Pics->https://flic.kr/s/aHsm8PCC4A
    Dec 13 2010
    FL
    ttt
    Active Member Two Rings Estarossa's Avatar
    Nov 02 2017
    Hyattsville MD
    Front seats for sale?
    Dec 13 2010
    FL
    Quote Originally Posted by Estarossa View Post
    Front seats from this car are gone.
    I do have a complete black leatherette set w/driver seat tear out of a 1.8t, and I also have complete heated sport cloth seats 9/10 condition out of a 1.8t
    Dec 13 2010
    FL
    bump
    Dec 13 2010
    FL
    bump
    Dec 13 2010
    FL
    make offers on parts! car is going to the junk yard soon!
    Veteran Member Four Rings Mattr567's Avatar
    Mar 20 2016
    1989 Honda CB-1, 1986 Suzuki SP200
    Quote Originally Posted by GrapeBandit View Post
    2.8 fwd 5th gear, to swap into my fwd 1.8t trans?
    Doing that has been in the back of my mind for a while.
    Sent from my ONEPLUS A5000 using Audizine mobile app
    FWD in the tradition of AutoUnion
    99.0 B5 A4 1.8TMS
    I turned a $750 car into a $10,000 car worth $2500
    Dec 13 2010
    FL
    Quote Originally Posted by Mattr567 View Post
    I'm pretty sure it wohld fit, but from what I can remember, ppl used to use a tdi gear for 5th
    Mar 20 2016
    PM'd.
    99.0 B5 A4 1.8TMS
    Nov 24 2012
    fl usa
    Need a good headlight switch and a decent steering wheel headlights which is more important can you help me
    Dec 13 2010
    FL
    Quote Originally Posted by jharl View Post
    I have both, a good headlight switch, and a good 3 spoke sport steering wheel w/airbag from my other car, a 99 a4 1.8t quattro.
    I'll send you pictures of them within a few hours!
    Dec 13 2010
    FL
    Pics of the steering wheel and the wiper/headlight/turn signal controls
    https://www.flickr.com/photos/990882.../shares/0M84Lr
    Dec 13 2010
    FL
    bump
    Active Member Two Rings kaydubmenace's Avatar
    Mar 14 2018
    Bradenton, FL
    bump
    Rear driver door panel available?
    Dec 13 2010
    FL
    Quote Originally Posted by kaydubmenace View Post
    I don't have any door panels from the 2.8. I do have a complete set from an 01 1.8tq, it's black with aluminum trim. I also have a complete set from a 99 1.8tq, but I am going to list those with the mint sport cloth seats I have. Those are black, with sport cloth inserts, aluminum trim, and bose speakers.
    If you want my sport seats, door cars and matching armrest, I'll make a deal lol
    Mar 07 2014
    Front bumper, driver fender and passenger rear door with pics?
    Sent from my LG-H931 using Tapatalk
    Dec 13 2010
    FL
    Quote Originally Posted by LegendaryT2 View Post
    Driver fender is gone. I'll get you pictures of the bumper and door later. Shipping to NYC?
    Mar 07 2014
    Most likely not. Either picked up or shipped to Orlando
    Dec 21 2013
    Q5, Q7, R8, B8A4 B5S4 E55AMG E63AMG
    How much for drivers side trans mount bracket? Shipped to 04042
    Sep 18 2017
    Chicago, IL
    Exhaust midpipes available? Talking about the "downpipes" between manifolds and rear exhaust. They contain the cats and secondary O2 sensors. Willing to ship to 60563?
    2001 A4Q 2.8 (ATQ) 5MT
    Dec 13 2010
    FL
    Sorry guys, been gone for a few days. The car is still together, but I can pull the stuff off of it this week if need be.
    Quote Originally Posted by Pizdets-b5 View Post
    $20 plus shipping, whatever that would be, maybe $15 or less
    Quote Originally Posted by m.wr View Post
    I have them, you are aware this is fwd and not quattro. I do not know if they midpipes are the same, so look into that if your car is quattro.
    I am willing to ship, $100 plus shipping. I'd have to measure them to see how long they are to get an exact quote, but I figure shipping to you would be around $30
    Dec 13 2010
    FL
    ttt
    Sep 18 2017
    Chicago, IL
    According to ETKA the only thing that could differentiate this part is auto/manual trans, and both our cars are manual so I'm fairly confident it will be identical. Thanks for pointing that out though. Will PM you to get things going.
    Veteran Member Four Rings fR3ZNO's Avatar
    Feb 09 2013
    WNY
    Mirror glass set available?
    "If one does not fail at times, then one has not challenged himself." - Ferdinand Porsche
    Dec 13 2010
    FL
    Quote Originally Posted by fR3ZNO View Post
    Yes, but there is a little browning around the edges, and the passenger one is a stubby.
    Feb 09 2013
    WNY
    Damn, thanks for checking.
    Jan 08 2017
    Raytown Missouri
    You still got ecu
    Dec 13 2010
    FL
    No problem
    Quote Originally Posted by madcell86 View Post
    You still got ecu
    Yes, $20+shipping
    Jan 08 2017
    Raytown Missouri
    Ok I’ll get tomorrow
    Jan 08 2017
    Raytown Missouri
    Please let me know when you ship thanks
    Dec 13 2010
    FL
    Shipped. PMing tracking info now
