Results 1 to 11 of 11
    Nov 11 2004
    Early 911s, 914-6 GT, A-H 100, BRE 510
    Chicago Area
    2008 A4: Brrrrrp Noise From Under Dash Help
    2008 A4 2.0T - I have had this intermiitent noise coming from under my dash for a couple of years. It will come and go - sometimes everytime I start the car and sometimes gone for weeks. I thought it was related to colder weather, but I really cannot make a temperature connection. However, I think it occurs more often in the fall and spring type of temperatures (40's to 50's).
    The sound is like a damper solenoid motor gear slipping when it tries to activate the damper (just a guess). It sounds like the plastic gear teeth are slipping - brrrrrrp, brrrrrp. So it will do that a few times and then have a prolonged brrr--rrrrp for several seconds. Not a big deal, but really annoying. It went away for a long time, so I forgot about it until the cooler temps returned a few months ago. I climbed under the passenger dash as it was burping and think I located the "box" it is coming from. There are two "boxes" on the passenger side just forward of the transmission tunnel console. I could not tell which one it was coming from, but it feels like it is one of those areas. Oh an another thing - it continues with the ignition off! Weird, eh?
    Has anyone experienced this before? Can you lend some assistance as to a fix? Would really appreciate any help you can provide. Thanks!
    Scott
    Junior Member Two Rings
    Oct 19 2006
    Virginia, USA
    Air con vent flap motors (located behind the glovebox)?
    Feb 22 2016
    SW Ontario Canada
    I feel your pain lol. When I turn my key I hear a faint tic, tic, tic sound but when the radio comes on its drowned out so isn't bothering me enough to do anything
    Established Member Two Rings snappytom's Avatar
    May 27 2015
    Wheaton, IL
    My 2008 does the same thing and I also assume it is a damper in the climate control system as it only happens after running the heat or AC.
    Does not really bother me and I don't have a fix to offer, but am curious if this is "working as designed".
    Nov 11 2004
    Chicago Area
    Quote Originally Posted by asgor View Post
    Could be. Hard to pinpoint the noise/vibration. Would love to be able to fix this issue.
    Mar 24 2013
    Oakdale, CT
    A10 mod?
    -Adam
    Senior Member Two Rings Ali SC3's Avatar
    Feb 08 2016
    B7 A4 2.7t
    Denver
    Brrrrrrrp almost sounds like coolant but I guess that wouldn't be a plastic sound... wrong brrrp lol
    Dec 14 2011
    Chagrin Falls, Ohio
    Maybe try turning your climate control off before you shut your car off. See if it makes the noise the next time you start it.
    May 27 2015
    Wheaton, IL
    Quote Originally Posted by snappytom View Post
    Update .... it's been warmer the past few days and I noticed the sound occurs when the car is shut off even if I have not turned on the heat.
    My sound is a low "brriiip" that repeats a few times and then stops. Seems like a damper or mixing flap trying to close.
    Veteran Member Three Rings allstock's Avatar
    Mar 19 2014
    greater sub of Chicago
    Is it a vrrrrrrclick or a zshzshzshclunk?
    Pretty sure those noises are normal. Like some mentioned, it's the comfort control doing its thing. You must've driven Japanese before this.
    May 27 2015
    Wheaton, IL
    Quote Originally Posted by allstock View Post
    LOL .... yes .... variety of noises like all of the above.
    As mentioned in one of my previous posts, it does not concern me and is just a curiosity.
    And you are correct ..... it's my first German car ....
