Originally Posted by
airjawed
Does the key in the trunk lock/unlock your doors? This is an Avant right? My car is a USA car so not sure if the lock and window logic is the same as for you. What is your lock coding in VCDS? Is it 16236?
I ask because if the doors don't lock from the trunk then it wouldn't work but may be due to the lock coding. To be honest I programmed from my door not from my avant rear hatch but in my owners manual it says I can lock and unlock from the back of the car. I'll try to test and let you know if I remember and get a chance.
Yes, all doors are locked/opened by trunk and when locking doors immo is activated correctly. Car is Europe Avant, pretty sure that the VCDS coding would have been 16236 but no access to that info now.
My feeling is that as the key clear is not working with either methods, something needs to be broken at the central lock module, will be start looking that next. Unless there is some ideas that I could still try to make the module to clear the old key info.
Removing the inner door skin is not big issue, but that still needs some time to do but as the keys seems to be stuck I am reluctant to do that as I have a feeling that it will not bring any solution in my case. Or was Speed4Avant having the same Adaptation Limit Surpassed foults while trying to code the keys with trunk lock? Did you try to clear the old coded keys while you were working on this?
