Results 1 to 40 of 45
    Jan 12 2010
    SE Pennsylvania
    Question Correct tire pressure? Basic issue, conflicting information...
    So here we go.
    Did a search and found conflicting information from members with many different Audi models.
    I have the oem 18" rims with Pirelli Cinturato P7 all-season tires.
    At the last service dealer pumped the tires to 44 psi all around.
    However, this is different than door jam sticker (41 all around) and much different than owner's manual (normal load, 36 front, 32 rear).
    I know that many drivers often adjust the tire pressure to personal preferences.
    So there's a BIG difference between 44 psi all around and 36 front with 32 rear.
    But which tire pressures are "correct"? or optimal? and why?
    While we're at it...
    What psi do you ride based on roads, performance, season, load, etc.---please specify whether your rims are 18" or 19" or 20" and whether your tires are all season or summer only.
    Mar 05 2014
    2020 SQ5
    PDX
    Weird my door cars reads 38/38 unless I am just stupid and missing something. I filled OEM 19's contis at 40 warm and call it a day. They were at 32/32 from the sales lot so it's quite a more enjoyable ride now. Much more responsive and don't tram line as much.
    Junior Member Two Rings
    Mar 28 2013
    Ohio
    41 PSI, as indicated in the door jamb, was way too rough. I set mine to 36 PSI.
    2016 MBM Audi S4 Manual
    2018 Tesla Model 3 Dual Motor
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Mine also shows 41 on the door, and that's what I run on all 4. It's higher than any tire pressure I ran on previous cars. I ran 36 in my A4.
    2021 Audi S4, P34 Intake
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    For my 18" 36 front. 32 rear, all seasons coni's
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    19" 39 front 33 rear
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Veteran Member Four Rings amz's Avatar
    Apr 29 2013
    Ottawa
    My '11 A4 read: 42/42
    My '12 S4 reads: 42/40
    My manual reads: 32/32 for both the A4 and S4...
    2012 S4 ~ Phantom Black - Mustang Brown - B&O - Sport Diff - DSG
    AWE Touring Exhaust | Roc Euro Intake | Eurocode Alu-Kruez | Eurocode USS Swaybars & Solid End Links
    Canada: the land of Quattro
    Mar 21 2015
    Mine says 41 for all four. I run them at 40. 19 inchers.
    Jan 10 2014
    San Antonio TX
    2014 manual says 33 rear 39 front up to 3 occupants and 41 all around for a fully loaded car. This is for the 19" wheel/tires
    Jan 03 2016
    Myrtle Beach, Sc
    my 2012 s4 says 41 all the way around. I had an escalade with 24's and I only ran 35psi, I have OEM wheels and conti tires, I alot of road noise and the ride is crappy i was thinking of going down to 32 all the way around. the tires are so stiff already being only 35's
    Mar 21 2015
    ^ OEM conti tires suck.
    Jan 03 2016
    Myrtle Beach, Sc
    what does everyone have for tires??? I want something quiet and performs well, we don't have really any bad weather here in south carolina except rain.
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Higher tire pressures will give you a higher load capacity , less compliant ride and greater tread-life, as long as you do not excessively over fill the tires. That will cause uneven tread-wear with center of tire wearing faster than the outside tread. Sidewalls on UHP tires are so stiff that you can lower tire pressure to get a softer ride., at the expense of tread-wear. BTW, I run 39 psi front and rear on my 19" Conti DWS tires.
    Jan 03 2016
    Myrtle Beach, Sc
    In an S4 I dont see the need for load capacity
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    My 12 S4 says 41 all around on the door. I set them to 38 psi all around and call it a day.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    read your door sticker it will tell you what to set them at
    Veteran Member Four Rings superswiss's Avatar
    Jan 07 2013
    San Francisco Bay Area, CA
    You can thank the US government for the rather useless door jam sticker. The pressure indicated on the sticker is the manufacturer recommended tire pressure for the OEM tires if the car is loaded to the brim with passengers and luggage. If you are only riding in the car by yourself or a couple of passenger, this pressure will lead to an unnecessary uncomfortable ride. You can still ride around like that if you prefer (I do sometimes), but don't expect a comfortable ride quality. For a normal loaded car for daily driving, the normal load tire pressure in the user manual is the recommended tire pressure. Don't expect the service departments to know that. Always check the tire pressure the next morning after service and properly adjust it.
    For comparison, here's an example of the sticker that you'll find in places such as Europe with the much more detailed information even for different tires as recommended by the manufacturer.
    2019 AMG C63CS, obsidian blk, blk leather w/ yellow stitching, aero pkg, CF pkg I+II, 19/20 wheels, lighting pkg, multimedia pkg, heat&vent seats, AMG perf seats, digital cluster, night pkg, parking assist, driver assist, european delivery
    2013 panther blk RS5, Ti pkg, blk leather/alcantara, nav pkg, sport exhaust, driver assist pkg, rear shade, alu kreuz, ECS spacers 15f/10r, ECS tru-float rotors, ECS brake lines, Hawk HPS pads, european delivery (sold)
    Jan 12 2010
    SE Pennsylvania
    Quote Originally Posted by superswiss View Post
    Your post and photo illustrates the comprehensive and proper tire pressures.
    What a stark contrast to the oversimplified and more often than not, wrong numbers listed on our door jams.
    This is a sad commentary on the lack of confidence our government has in a typical owner's awareness to change tire pressure based on load.
    And to think that even dealerships are unaware of the correct tire pressures is very sad and inexcusable., simply pumping up our tires to the absolute MAX.
    As we all know, suboptimal tire pressure affects many things including ride, handling and safety.
    Thanks for posting.
    Well done superswiss!
    And based on your post, our owner's manual lists the proper tire pressures.
    Any changes to these pressures are driver preferences.
    Apr 05 2012
    Earth
    The sticker on my 2013 S4 door jam is similar. It gives the recommended "normal" and "fully loaded" tire pressures for the 18" and 19" tires.
    Jan 14 2009
    pasadena md
    Quote Originally Posted by 4wheelpilot View Post
    Thanks for posting.
    What are you talking about wrong numbers listed in our door jams??? The sticker in our door jams is correct for our cars. So look at your door jam either drivers or passenger side has it and it will tell you what to set the tires at. He just gave you an example of what it looks like. The door jam sticker is knowledge of the gods. Now if you like something a little different from the pressures listed there that's up to you and your preference. But most dealers inflate to whatever is listed on the door jams. If not you would get a tire pressure light.
    Jan 12 2010
    SE Pennsylvania
    My door jam has one pressure listed...41 psi.
    This is different than my owner's manual which lists 36 front, 32 rear for the 18" oem rims with all season tires for normal load.
    Jan 07 2013
    Quote Originally Posted by JohnEnglish View Post
    Where are you located? The typical sticker in the US looks like this. It only lists the full load tire pressure for the tires the car shipped with. This one is from my 2013 RS5. Then compare it to what it actually says in the owners manual.
    Mar 05 2014
    2020 SQ5
    PDX
    It's just 'cus our American asses are generally fat :-) Soooooo a couple extra PSI here and there, LOL.
    Feb 08 2016
    Mexico City, Mexico
    This is the sticker on my "Mexican" 2012 S4. It only has info for 18" tires thought. Not much help for those of you with 19".
    Jan 07 2013
    Quote Originally Posted by chaos2984 View Post
    Not true. Whenever you inflate your tires you are supposed to reset TPMS so it learns the actual tire pressure. Dealers do this. It's even listed on the work order. Besides, TPMS doesn't alert for over-inflation and it only alerts for 20-25% under-inflation.
    One of the issues with dealers inflating your tires is that generally when you bring in your car, the tires are warm, because you drove there. It takes 3+ hours for tires to cool down to the point where it's ok to check and adjust the tire pressure. Better is to leave the car sit over night and check first thing in the morning. I usually decline for them to adjust my tire pressure. Sometimes I forget and then it's usually wrong once the tire have cooled down over night, because they adjusted the tires while they were too warm.
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    36psi COLD on any 19" tire is more than enough air imo. That's what I set mine to and the door jam says 41
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Veteran Member Three Rings Midnight_Rider's Avatar
    Jan 25 2015
    VA
    People don't look at tires for tire pressure anymore these days?
    C7 Z06 3LZ - AMR Long tube header and exhaust, Halltech Intake, tune.
    B8.5 S4 - Daily commuter. IE Stage 2 ECU/TCU, IE intake
    AP1 S2k (glass rear window) Black with full red interior - all suspension mods - SCCA car
    Evo VIII - AEM EMS, Cosworth Cams, intake, Whiteline front and rear sway bars, exhaust, etc., etc., etc..
    Jan 14 2009
    pasadena md
    Interesting. Most of the systems i have worked on while working at dealers had the pressure spec hard coded into the system. I guess ours just work a little different. Which is kinda good for less lights and ease of relearn and no sensors for pressure too
    Jan 07 2013
    Don't remember Audi ever having hardcoded tire pressure. Up till 2009 they where using pressure sensors in the tires, and it was the same thing there. Reset TPMS to set the actual pressure. Later Audi switch to indirect TPMS which measures frequencies in the wheel assembly and does a spectrum analysis to determine if the tire pressure is low.
    https://en.wikipedia.org/wiki/Tire-p...#Indirect_TPMS
    Jan 25 2015
    VA
    This is correct. They determine by the rotation, and something else.
    Mar 21 2015
    Quote Originally Posted by Midnight_Rider View Post
    It's in the link you quoted
    Mar 01 2016
    Gone: 2007 Acura TL Type S, 2004 Acura TL, 2005 VW Passat 1.8T
    NH
    My Door Jam sticker says 41 PSI front and rear on a 2013 with 18 inch stock wheels.
    Veteran Member Three Rings VenturiRS's Avatar
    Dec 27 2008
    I do 38-40 on the 19s, 40-42 on the 18 winters.
    B8.5 Estoril Blue S4 | P+ | DSG | SD | ADS | B&O | CF | Nappa | Advance Key | CF Badges
    Established Member Two Rings Arn560's Avatar
    Aug 10 2015
    Toyota Sequoia SR5, VW Jetta
    Monroe, NJ
    As the door sicker says, 41 psi at all 4 corners ( 19" Peelers)
    2011 B8 S4 Prestige, Ibis White, B & O, Nav, Carista Mods, Sports Differential, Black hide & Alcantara, CF inlays, S4 rubber mats, 19" Peelers, Ziza interior LEDs Lubed with Mobil 1.
    Veteran Member Three Rings Senseless's Avatar
    Aug 11 2015
    Phila vicinity/ PA/ US
    Thanks for explaining that! I reduced my 18"s from 41 all around to 39 front, 35 rear as per the manual for normal load. The ride is noticeably more pleasant and the tires will probably survive potholes better.
    Apr 05 2012
    Earth
    I'm in Canada and my door sticker looks like the table in the manual.
    Sep 10 2012
    DFW
    This has been a thread for years and for the life of me, I can't figure out why people don't pull out the owners manual and read up on this. Audi has posted their concerns about this and still people max it out at 41 psi. The Manual on the 2013 19" is 39 front and 33 rear, and I would suspect that's because there's more weight in front then the rear.
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Jan 12 2010
    SE Pennsylvania
    Quote Originally Posted by TexasDfwS4 View Post
    The very different psi numbers in the owner's manual versus the door jam is what prompted me to start this thread.
    I searched beforehand and couldn't find a clear answer to this very basic yet very important issue.
    What concerns has Audi posted about these discrepancies?
    Thanks
    Sep 10 2012
    DFW
    Audi post the max psi on the door but they have gone the distance to add their recommendations (concerns) in the owners manual. If Audi didn't have any concerns about the handling they wouldn't have added the tire pressure to the owners manual, that's all I meant by this.
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Aug 11 2015
    Why would I consult the manual if the PSI is listed on the door jam? There's one line that says "consult manual for additional information", but nothing that says "this is the recommended pressure for fully loaded vehicle".
