Results 1 to 30 of 30
Thread: Dsg fart
    Veteran Member Four Rings s4boost's Avatar
    Jan 08 2008
    Franklin/TN
    Dsg fart
    Some s4s have dsg fart like crazy 1-2 and 2-3 shift. I don't know if I've ever heard mine fart on the 2-3... Any reason why?
    2012 S4 Ibis White S Tronic Prestige APR stg 2+ V3 CTS Turbo Intake
    2002 Silver S4 6MT Premium Package Stg 3 -SOLD
    Established Member Two Rings pfft's Avatar
    Jul 24 2014
    '05 Nissan 350z
    Grand Rapids, MI
    Usually gotta be going as fast as you can and at highest RPM for the 2-3 fart. You're saying you are doing that but nothing?
    Jul 10 2015
    Yea I noticed it only farts if you shift above like 3.5k to 4k rpm.
    Jan 08 2008
    Franklin/TN
    Quote Originally Posted by pfft View Post
    Correct. Maybe I'm just not hearing it. Any other thoughts?
    Veteran Member Three Rings mjr034's Avatar
    Jul 07 2014
    2015 Mazda 3i GT
    Michigan
    can someone elaborate as to what the DSG fart is..?
    2013 S5 3.0 TFSI ~ Prestige | DSG | Brilliant Black | Carbon Atlas
    | 034 | APR | AWE | BBS | BFI | BILSTEIN | ECS | VORSTEINER |
    Jan 28 2013
    Quote Originally Posted by mjr034 View Post
    https://www.youtube.com/watch?v=hEin3vVF3SQ
    4 Second mark
    Mar 05 2015
    2009 A4 Cab: S-Line / 1996 Camaro Z28
    East Granby CT
    Supposedly it's tuned out of Stage I and Stage II tunes.... So more of stock thing - but you really can't miss it - aptly named "Fart" because it sounds like exactly that - and just like "Farts" it's highly entertaining drawing giggles and laughter from almost all (except most wives....)
    2012 Moonlight Blue Metallic S4 | Premium + | DSG | 19" Peelers |Sports Diff | MMI w/Nav | B&O Audio | Advanced Key |
    After-Market Add-Ons: Rallitek Aluminum Paddles | USP LED Interior Lighting | Phillips Xtreme +50% Headlight Bulbs
    Performance Upgrades: 034 Stage 1 ECU & TCU | | APR I/C |
    Stoptech Cryo Slotted Rotors with Porterfield R4-S Pads |
    034 Springs / Koni Yellow shocks | Tires = Michelin Pilot 4S (255/35/19)
    Veteran Member Three Rings Silverbullet S4's Avatar
    Mar 10 2015
    CO - 6,200' +
    Quote Originally Posted by grovlet View Post
    Mine still farts....
    2013 S4 - APR Stage 2+, DP, CPS v3, BLQ 20s, Solo Werks coilovers, CR-15, EBC Rotors F&R, Deval diffuser, AWE exhaust & USP Intake - TD1 inevitable
    Mar 05 2015
    East Granby CT
    Quote Originally Posted by Silverbullet S4 View Post
    Good to know - as I often cause it to occur - for S78ts & giggles.... So if I ever go Stage II - it will still be part of the fun!!
    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    Long story short, the DSG can shift quickly enough that the drop in engine speed because of the difference in rotation speed would cause damage to the clutch packs. To remedy this, the ECU temporarily stalls the engine to quickly drop the speed to match the other clutch system. The "dsg fart" is the temporary stalling of the engine.
    In higher gears it's not as necessary because the torque potential is much lower, therefore it has less of a chance of damaging wearable parts.
    It also sounds freaking awesome.
    Established Member Two Rings Woodybangs's Avatar
    Jan 08 2016
    MI
    It's the ECU reducing timing during shifts.
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    Quote Originally Posted by hotleadsingergu View Post
    All of this is wrong.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp Package
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    Quote Originally Posted by CELison View Post
    Lol, well what's the right answer? I was thinking it was the release of bypass boost during shift?
    2021 Audi S4, P34 Intake
    Oct 14 2012
    Empty...for now...
    SE PA
    FWIW, every time I see "dsg fart" written, my brain initially reads it as "dog fart". Every time.
    SOLD 2015 Daytona Gray S4
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    Quote Originally Posted by s4boost View Post
    You should have the blip on all upshifts if you don't have the TCU tune from APR (when in AMAX mode the blips are gone)...
    You can hear mine blip every single gear on this pass.. I am running stock TCU in this video, just stg 2 APR v3.1 ecu tune. As for your car, I'm really not sure why it wouldn't be doing that... I think I remember you posting about some weird shift behaviors. Hopefully it's not an actual issue with your mech unit...
    My other guess would be that you're on the earlier version of the ecu tune from the newest release. My car kept hitting the rev limiter on v3.0 thus why they released a v3.1. Can't remember if the "fart" was also affected by that version...
    Jun 18 2015
    Cleveland
    Thanks for your helpful response. Care to elaborate, instead of just being a negative nancy? The DSG Fart is the ECU diverting a bit of fuel into the exhaust to reduce torque differential by slowing engine speed. Please...explain how I'm wrong.
    EDIT: For those thinking it may be a way to maintain Supercharger/Turbo pressure, it occurs on NA cars, as well. It also occurs on extremely-quick manual shifts for manual cars and motorcycles. It IS the ECU determining that the differential is too high and cutting acceleration by diverting the fuel into the exhaust. The "Fart" is the fuel burning in the exhaust system directly.
    DOUBLE EDIT: This guy is someone that has told people his tuned car can't be overheating because it's only 15F outside and that if you don't know how to drive manual it's probably because you were "raised by 2 women". Thanks for your input, CELison.
    Jan 08 2016
    MI
    That would destroy catalysts. All it is is reducing timing and therefore power quickly during the shift.
    Feb 23 2010
    Emmaus Pa
    It cuts spark so the fuel dumps into the exhaust. That is the "fart" sound. Anyway, the tq potential is higher in higher gears as there is much more load on the clutch packs. Saying that it's only applicable in lower gears makes no sense. FYI, the car will do this at all WOT shifts, not just in low gears. Overheating and heat soak are 2 completely different things. You should look into that as well. I'm so sorry I hurt your feelings though.
    Cheers
    B9 S4- EPL/AWE
    Feb 23 2010
    Emmaus Pa
    Quote Originally Posted by Woodybangs View Post
    That what's it is. You can see the black smoke out of the exhaust from the fuel burning.
    B9 S4- EPL/AWE
    Jun 18 2015
    Cleveland
    Cheers
    You didn't hurt my feelings, you just think someone else is wrong when they're not, and you're providing incorrect information. What you said would be true if you used "horsepower" instead of torque potential...but in lower gears, the larger gear provides the equivalent ratio of extra torque to the wheels as the differential in gear size. At the same rotational speed of the engine (RPM), you can provide more torque; therefore, the lower the gear, the more potential torque being applied to the contact points. If you shift at 5,000RPM from 1-2 and 5,000RPM from 6-7, you're applying more potential torque to the clutch pack in the former.
    As for the 'cuts spark so the fuel dumps into the exhaust'...you haven't proved me wrong, at all. The ECU determines that the differential is too high and cuts the engine speed by stalling it out for a moment. How is that wrong, exactly? (Hint: It's not)
    As for the heat soak business...I know the difference well. There is absolutely nothing to say that your intercooler can't be heatsoaked at 17F. It's ludicrous to think that it can't, especially considering that you mentioned in the thread you did a few hard pulls. It's absolutely possible that your intercooler can't handle the amount of heat the car is generating at 17F, which is the entire reason for people to replace their intercoolers with aftermarket units. The outside temperature would have to be in the -50Fs for it to be a nonissue.
    Keep acting like a superior tool, though. People love that.
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    It's fuel that makes the fart guys..
    http://youtu.be/kXI78224lYY
    May 20 2012
    Chicago, IL
    Love farting.
    Matthew
    Sent from my SAMSUNG-SM-G925A using Tapatalk
    Veteran Member Three Rings SForePlayin''s Avatar
    Jan 11 2014
    2015 Toyota Camry SE, 2015 Lexus IS 250 AWD, 2018 Honda CRV LX
    North Carolina
    2014 S4 Ice Silver Metallic|Black Optic|DSG|Sport Diff|ADS|Fine Black Nappa|MMI Nav +|B&O|Carbon Atlas Inlays|Supercharged Badges|Advanced Key|OEM Floor and Trunk Mats|Michelin PSS A/S 4|Lamin-x Yellow|deAutoLED|Carista|
    2003 A4 Sedan | Light Silver Metallic | MT6 | 3.0 Quattro | - Traded In
    Instagram - sforeplayin
    Dec 04 2015
    2014 B8.5 S4, 1989 Supra MKIII
    Nor-Cal
    Mines giac stg2 with tcu tune and farts are even more aggressive than stock. Also have awe touring and it farts on every up shift under significant throttle, wot it's awesome and everyone looks lol
    Established Member Two Rings Arn560's Avatar
    Aug 10 2015
    Toyota Sequoia SR5, VW Jetta
    Monroe, NJ
    Love the fart. Best part of owning an S4!
    2011 B8 S4 Prestige, Ibis White, B & O, Nav, Carista Mods, Sports Differential, Black hide & Alcantara, CF inlays, S4 rubber mats, 19" Peelers, Ziza interior LEDs Lubed with Mobil 1.
    Senior Member Three Rings acturater's Avatar
    Sep 17 2013
    philadelphia
    I remember mine faded away over time. I wonder if there was some kind of carbon buildup somewhere along the way?
    It was very prominent in the beginning, I remember loving it and my wife commenting on it as well. I went stage 2 sometime thereafter, but I also put it completely back to stock and didn't notice it as much, so I don't think it was the tune.
    Mar 10 2015
    CO - 6,200' +
    Quote Originally Posted by acturater View Post
    Maybe you just got used to hearing it and now it's not as noticeable to you? Wouldn't think it's something that can just go away.....
    Veteran Member Three Rings sirsycott's Avatar
    Sep 20 2013
    Orange County/CA
    i wouldn't necesarrily put it at "stalling" , i've logged a few cars though the dsg shifting
    between all of that happening , i do see the timing change to the new gear to offset, but it never really tries to zero out it does lower rather fast , fueling doesn't cut off beetween the shifts infact stays at max requeested value from one gear into the next shift
    timing retarding vs stalling would be better semantics?
    i'm just tossing in big words for the fun of it
    plus when everyone reads stalling, they're assuming the engine stalled or seized because of a bad manual driver
    2018 TTRS
    Veteran Member Four Rings xuandatou's Avatar
    Oct 17 2012
    NoCal
    Just curious why would you want dat fart so bad?
    2013 S5 Build Thread
    2001 S4 Avant
    2017 Ducati Monster 821
    Instagram
    Gone but not forgotten:
    2011 Q5 2.0T
    2011 A5 2.0T
    2013 S5
    2007 A6 3.2
    Jan 28 2013
    Quote Originally Posted by xuandatou View Post
    Same reason people want really loud exhausts and shit. Cuz race car. Wish I was 16 again so I could appreciate the fart, but I'm not, so I don't.
