Results 1 to 12 of 12
Thread: Tints
    Veteran Member Four Rings PKmode's Avatar
    Sep 19 2005
    Milwaukee, WI USA
    Tints
    First off, I had my windows tinted in the same fashion I do all my cars. That's 30% film all around and a sun visor strip of 5%. It looks good as is a nice functional upgrade for me.
    Next, I decided to try out Headlight Armor Light Smoke tail light vinyl to try and mimic the facelift models slightly. Plus, I think it looks good with the darker colors in general as long as it is light enough that it could pass for OEM in terms of appearance. Worth mention is I have some vinyl experience and used to work for a vinyl sign company years ago. I did proper prep which included wash, claybar, then clean with 50/50 mix of distilled water and denatured alcohol.
    Compare
    Note the bumps in the finish. Even with care, it is hard to get a perfect finish due to the non-flat shape our our lights. They really need to be contoured around the light and all the air pushed out working from the center outwards.
    Now compared to the other side.
    Final product looks good from a few feet away but I will say the finish is not great. Even if it were perfectly installed, there still would be a general bumpiness almost like a heavy orange peel compared to the smooth plastic finish. At this point, I'm going to try and smooth them out a little better and run them like this for a month or two. Then when I have some more time, I'll get the car in to have the tail lights tinted with clear coat like I had originally planned. I liked the idea of having this removable but I think it looks good, so permanent is fine with me when the finish will be perfect.
    So, against my better judgment, I tried this product out. It pretty much proves my signature "Do it right, or don't bother" as I just wasted $70 and the time. It would probably look really good to some and they clearly have a product people like. I'm a detail orientated guy and this would not pass my standards of quality. The finish in a best case scenario still isn't there. Great from a few feet but not up close. In addition to the orange peel, there are some spots that are slightly hazy and it is in the film or under it. Also, there were some light vertical scratches in the same spot on both pieces of vinyl right out of the package when unrolled. These marks would have been imperfections but there are far worse imperfections in the finish now so those are not a concern. Overall, I would not recommend this product for higher end vehicles like this. It seems the only way to do it right is with automotive quality clear coat that has been tinted and sprayed on in a proper shop with quality prep. This goes to show, there are no shortcuts if you want it done right.
    Do it right, or don't bother.
    Sep 19 2005
    Milwaukee, WI USA
    Oh, I also threw in a set of the RS6 style pedals. These were the knock offs and the finish isn't as good as OEM but these just get dirty and have no real functional gain so whatever. Worth note, the rubber molds actually had Audis part number and the four rings were scratched out. My guess is these came from someone who tried to be an Audi supplier and couldn't meet quality standards. Forgive the dirty carpet. It is still the tail end of winter up here and I haven't given her a good deep cleaning just yet.
    I think they look good enough for $43 shipped and literally 10 minutes to install the set.
    Feb 11 2016
    earth
    Great post and thanks for sharing! I'm debating going with 30% or one step darker on the windows
    Sep 19 2005
    Milwaukee, WI USA
    Sure, no problem. FWIW, IMO, anything darker becomes hard to see out of at night. I've had 20% and didn't like it. I know there is always some yahoo that comes in saying he runs 15% or less all around and has no problem but that's BS. Also, our state law is the front windows can be no darker than 50% so I'm already running the risk of a ticket but that's never happened despite having 8 different cars done in this fashion. I was called out on it by State Patrol once and he even measured the glass on the spot (came of to 27% when including the factory coating). Still, he didn't give me a ticket. Phew.
    Veteran Member Three Rings RRF985's Avatar
    Apr 12 2014
    Atlanta, GA
    I really like the tinted tails. I've considered the same. I have a question about the pedals. I have a set of OE RS6 pedals. How hard is the dead pedal install? I'll be throwing these on in a couple weeks.
    2017 VW GTI 6MT Autobahn
    2012 A6 3.0T P+ | Oolong | Black | Black Headliner | Sport | Side Assist | Cold Weather (sold)
    Sep 19 2005
    Milwaukee, WI USA
    The dead pedal is by far the hardest part and it may have taken a lot longer if I followed the Audi directions which would have you remove that side trim panel all together. I read others say to pull it away at the base and not to be gentle with it. I knew in advance what I was dealing with and man handled that panel. I was able to get it done in 5mins, literally. When you are taking off the old dead pedal, pull that panel away towards the gas pedal essentially and then you can slide the old out and the new in. Then its a quick few snap connects and you're done. Easiest Audi part install you'll ever encounter.
    Senior Member Two Rings LW3's Avatar
    Feb 09 2014
    NC
    Nice write-up. Thanks for taking the time to do it. What tint brand/type is installed on the windows?
    14 RS7 | 16 SQ5- Sold
    Sep 19 2005
    Milwaukee, WI USA
    Quote Originally Posted by LW3 View Post
    I'm not certain on that. I know it's a 3M product but not sure which one. Likely whatever the best stuff is as they are the best shop in town and do all the pro athletes cars and the new European car dealers as well.
    Apr 12 2014
    Atlanta, GA
    Quote Originally Posted by PKmode View Post
    Thank you very much.
    Veteran Member Three Rings arrivalanche's Avatar
    Jun 08 2014
    Placentia, CA
    Did the same on ours. After I got the new S6 the A6 just looked too bright.
    -AARON-
    2018 S4 Black Optic
    2017 S6 Black Optic - Sold
    2016 S6 Black Optic - Sold
    2014 A6 3.0T Black Optic - Sold
    2014 S4 3.0T Black Optic - Sold
    2012 A6 3.0T - Sold
    2008 A4 2.0T - Sold
    Established Member Two Rings martz's Avatar
    May 01 2014
    2014 Audi RS7, 2010 Audi Q7 4.2 TDI, 2014 Ducati SF848, 2003 Nissan 350Z Roadster
    Australia
    Quote Originally Posted by arrivalanche View Post
    omg the audi rings are love hearts lol!!!
    Sep 19 2005
    Milwaukee, WI USA
    Nice. I'm debadging the rear soon as well.
