I posted the following text to PW, but as I also have an aftermarket head unit in my B6, I suspect a similar possibility might exist...
"Decided to test out my new Foxwell VAG-COM by attempting to reconnect both of my key fobs (which did work at one time) to my 2002 Passat.
I was successfully able to clear channel 00, but when it came to setting 01 for two keys, it didn't work.
I looked in my Bentley manual to see if any answers could be gleaned and found a statement that one could damage a code scanner if the 'wrong' radio (I.e. aftermarket) is installed.
I suspect it might be the reason I couldn't get it to work, providing there's any truth to that statement.
It did recommend disconnecting the radio to avoid possibly damaging the scanner, which I will probably do when I have a free couple of hours.
Thoughts?
Sent from my SAMSUNG-SGH-I337 using Audizine mobile app
