Results 1 to 26 of 26
    Feb 04 2016
    Atlanta, GA
    Brake pads/rotors recommendations
    I read a few threads around the forums, and it seems like I would have a good idea of what to replace my brake pads/rotors with if I were racing, but I'm not :(. Yet (just kidding). So, I'm curious as to what everyone's opinions are on brakes for a not terribly cold, not terribly hot climate like Atlanta for a daily driver that is a bit aggressive with his driving!
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Im running Akebonos. They're great imo. Good bite, less grabby than OEM, and virtually no dust.
    Ive only ever tried these and OEMs, so I have a pretty biased opinion. However, lots of guys here love theyre Akebonos as well
    2008 A4 S-line 2.0T
    JHM Stage 2
    Jun 17 2013
    jersey city nj
    Hawks HPS Rule...... Non slotted or cross drilled rotors. Stock rotors are the best. All other will vibrate or pulsate the brake pedal
    I stop so hard, Im afraid of the person behind me just climb over my car while braking
    Veteran Member Three Rings Obsidian's Avatar
    Jun 16 2012
    '06 A4 2.0t
    Valley of the Sun
    Quote Originally Posted by vce1232000 View Post
    Hawks HPS Rule...... Stock rotors are the best.
    +1
    2006 Audi A4 2.0T / 6MT / Brilliant Black
    APR stg II / 034 Motorsport / aFe / Avus
    Feb 06 2016
    Honolulu
    I've used Akebono's on all my cars.
    Hard to beat them for street driving.
    Very low dust and decent braking.
    Any rotor from the major brands are fine.
    I've used them all with very good results.
    Ate, Zimmerman, and Brembo.
    Just make sure you clean the area's that the rotor will rest on.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    OP, any quality rotor brand will be fine. Centric 120, Zimmerman, Brembo, Stoptech, etc...
    That simply isn't true.
    That said, the only reason to go with slotted or cross-drilled is aesthetics. I happen to prefer them over blanks in that regard.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Feb 06 2016
    Honolulu
    Quote Originally Posted by LINDW4LL View Post
    Actually, with slotted or "drilled" rotors it depends on who is the manufacturer.
    There's more to the technology than taking a drill press and making holes in the rotor!
    If I'm not mistaken even Porsche's rotors would end up with stress cracks.
    I think Porsche started to source rotors that had the holes cast into the design of the rotor rather than drilling
    Jun 17 2013
    jersey city nj
    And the old slotted/cross drilled rotor great debate starts again....lol
    Dec 10 2011
    CLT | MKE
    This isn't a matter of opinion.
    Drilled or slotted rotors do not inherently cause vibrations or pulsations. It just is not true. Furthermore, hundreds of vehicles are equipped from the factory with drilled and/or slotted iron rotors. By your logic, every single one would have a pulsating or vibration issue due to the inherent design flaw of drilled/slotted rotors
    -Hayden
    Veteran Member Four Rings dalmation53's Avatar
    Aug 20 2013
    Miami
    LOL I will agree with you that was dumb what he said indeed..I put on drilled and slotted on all 4 sides and all I really notice is they get cool very fast which means they won't fade as quick as blanks.
    Ivan
    Veteran Member Three Rings panman142's Avatar
    Jun 21 2015
    V8_4Runner
    Akron, OH
    Check out EBC Green stuff or Red stuff, nice alternative to Hawk and pretty well priced! Also for rotors grab some S4 rotors with the carrier to run em!
    Veteran Member Four Rings derrek's Avatar
    Jul 23 2010
    arizona
    I run carbotech bobcats for my street pads but my old Brembo pads were better (more aggressive). For the track I use carbotech xp10 front and xp8 rear. I wouldn't recommend those for street use though.
    As far as drilled and slotted rotors vibrating it's probably due to improper break in leaving an uneven layer of brake pad compound on the rotor. For stress cracks 90% of the time you see cracks in the brake compound on the rotor(nothing to worry about).
    Jun 17 2013
    jersey city nj
    Hundreds of car come factory equipped with them. Really. From the research Ive done the ones that do come on high end sport cars/luxury and designed holes that are casted when made and not actually drilled afterwards. I had cross drilled and slotted rotors on 2 previous cars before and had same issue's. I them with stock blanks and problem is gone. These are my own experience with them. If you dont agree thats all well also. Just sharing
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by dalmation53 View Post
    I will not even respond back to name calling or saying someone is dumb. Thats just very immature imo
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by derrek View Post
    I seen this when I researched when my brake pedal was doing this. Ive sent out to get resurfaced. them back on and re-bedded them again. Still same problem. I even different new pads. Bought some Stop Tech at the time. By the way they are free to someone who can use them. Dont particular care for them over the Hawk HPS's. Keep in mine they are for the RS4 calipers. To this problem once in for all Im going to have to buy dealer rotors. As I a few different B7 RS4's from a friends repair shop with the owners to confirm the possible . Their brake pedals had absolutely no vibrations at all. The 1 that I did that had the very slightest vibration-pulsation had cross drilled-slotted rotors. Maybe thats why from the factory B7 RS4 didnt have slotted or drilled. Dont know for sure. Its just a very hard pill to swallow to purchase $1000.00 dealer rotors. Knowing that my rotors are still within wear specs
    Jul 23 2010
    arizona
    How are you bedding them in?
    Oct 02 2006
    Wadsworth,OH
    Akebono Euro Ceramics or HAWK HPS are our most popular selling pads. Can't really go wrong with either. HPS will ultimately handle higher brake temps if you do more spirited driving though.
    We've also had great feedback from our GEOMET rotors. We offer them in slotted or drilled and slotted. I've been running the slotted version for about 6 months and have no complaints and they still look great even through winter.
    Check out our collection below!
    Let me know if you have any questions or concerns.
    Jason
    Aug 20 2013
    Miami
    What you said was dumb..I didn't call you dumb...again you always misread things all the time man...live a little more don't be so angry at the world.
    Sent from my C5306 using Tapatalk
    Ivan
    Veteran Member Three Rings allstock's Avatar
    Mar 19 2014
    greater sub of Chicago
    http://www.audizine.com/forum/showth...oo-dumb-to-ask
    Dec 10 2011
    CLT | MKE
    OE RS4 rotors are drilled.
    -Hayden
    Jun 17 2013
    jersey city nj
    I try to answer question and contribute worthiness to . I do joke around with my emotions and such. But I never insult someone or try even to degrade them in any manner. If Im wrong. I man up and admit it. There nothing wrong with being incorrect. Thats life. Be the bigger man and move on. I stay away from people that have nothing to add constructivity and negativity. It just drains to much out of you. If they post they need help and dont add anything positive on . I know the answer but I will just circumvent the entire thread all together.
    thank you allstock for the humorous thread
    Jun 17 2013
    jersey city nj
    Ooh ....Well you are then sir and Im . Im going to have to just ante up the $$$$ and purchase a pair of oem rotors. Even thou the pedal only slightest vibrate/pulsate under extreme hard braking. It just bothers me
    Feb 04 2016
    Atlanta, GA
    Thanks for the info everyone! I'm glad it sounds like I have more options than simply OEM rotors considering those are quite pricy :)
    Apr 12 2015
    '06 VW TOUAREG (V8), MTN Bike
    FALLON, NV
    Thanks for the info too, everyone. Learning as I go.
    I'M THE ORIGINAL OWNER OF '07 B7 A4 2.0T 6MT Q (62K): JHM 91 OCT STG 2 | CARBONIO INTAKE | 034 REAR SB | JHM TP | JHM DP-Y | B6 S4 CB
    Nov 26 2011
    2018 F80 M3 ZCP, 2007 RS4
    I had the HPS on my 18z's and they squealed like crazy but performed very well. Hawk sent me some Performance Ceramics to try and get rid of the noise and I gotta say, they feel a lot better than the HPS pads. I bed them the same way I did the HPS pads and they grab more quickly and need less pedal effort to stop. Also they dust even less than the Akebonos I had on my stock brakes. Hawk PC's are also a good choice for a daily that many overlook.
    But HPS will perform better at higher temps I'm sure.
    Feb 04 2016
    Atlanta, GA
    Woohoo, got some akebono pads and zimmerman rotors lined up on europaparts! Definitely more reasonable than going OEM all the way :) I maaaay end up getting some hawk performance pads, but I'm still on the fence.
