• 2001 Audi S4 Avant
• Brilliant Black Exterior
• Ebony Black Leather Interior
• Clean Title and registered
• All Wheel Drive
• V6 Twin Turbo, 6 Speed Manual Transmission
• Mileage 145K
• Motor Mileage 105K
Service/Recent Tune ups within the past 1,000 miles.
-Oil Change with synthetic oil
-Timing belt/ water pump service
-New rear wheel bearings
-New tie rods
-Fresh alignment
-New Break pads
-Valve cover gasket replacement
Modifications
-Frankenturbo F21
-Frankenturbo over sized inlets
-ER intercoolers
-710N diverter valves
-034 Throttle body boot
-SRM 3” Intake with 85MM maf. w/ K&N filter
-SSAC 2.5” catless downpipes
-SSAC 2.5’’ tru-dual exhaust
-Bosch EV14 750CC injectors
-Bosch 044 Fuel Pump
-RS4 Clutch
-BC Coilovers with fully adjustable height and rebound
-Jfonz/Auto Union tuning custom dyno tune w/ program switcher
Evap/EGT/sensor delete
460whp/450lbs.tq on E85
420whp/450lbs.tq on 91 Oct.
All the work/tuning has been done at Auto Union Tuning in Huntington Beach, CA. Auto Union performed the custom dyno tune and the car put down impressive numbers (460whp/450lbs.tq on E85,420whp/450lbs.tq on 91 Oct.) I have receipts and documentation of every item purchased and serviced for the car. I had the car replaced with a motor with less mileage (105K) with a fresh timing belt/thermostat/waterpump service and other small items required for a motor. The car drives perfectly and is located in Brea, CA. The reason for the sale is because I’m back in graduate school out of state and the car is not driven. The car is mechanically perfect shape, there is no single leak of oil or coolant, and would not need another major service within the next 50K, as long as routine oil changes are performed. The bad is the exterior is not in the best shape, the hood has oxidation from being parked outside, the fenders have been pulled, and the tires need to be replaced soon. Besides the exterior blemishes, the interior is in great shape, and no dead pixels in the speedo. I’m asking $10,000 OBO for the car as-is. If you have any questions, you can contact me at (949)632-3437. Thanks.
