Originally Posted by
Agilis
Jizzle some advice: You sound like a nice, knowledgeable guy but you cannot ask for advice then get upset at the advice that you receive. There's a lot of knowledgeable members here who all have technical experience which carries a unique set of opinions that you may not agree with
. Patience and understanding that others are just trying to help goes a long way here. Good luck with your conversion!
I want to reassure everyone,im not getting upset with the advice given. More like addressing questions and concerns with the wrong tone of voice, but with typed letters lol. But I promise, it's purely taken out of context if that's how my responses are taken. I mean the best and have the best intentions. This isn't a project I'm trying to "cobble" together and ignore all safety concerns. This is still very much an idea of mine that I would like to utilize. I really like the style if this caliper, and soo many other platforms of cars had adapted this caliper with great results. All using brackets, welded together brackets, drilled holes and God knows what else? From what I researched and from people I know, they hadn't reported failures. I would very much like this to work so I'm trying to find the best solution. My ideas from the beginning are just that, ideas.. I drive my car everyday if the week. 20k miles a year and I have a family. So this needs to be a safe end result of a project.
auditink
jizzle85,
This just doesn't seem like the best idea..... But it seems you have your mind set on doing it this way. I think maybe you were not looking for advice but maybe some reassurance that this method of drilling through the knuckle would work.... will it work, who knows... maybe.... BUT is it the right way to do it, NO. would I do it this way... HELL NO. Do it right the first time and don't try and try and engineer around what should be done in the first place. you are a machinist so why not machine a bracket to use all existing holes as they were intended. if you don't feel confident on making a bracket for yourself, there are others that can make this happen for you so you and everyone that drives around you can be safe. The control arms and knuckles are not as strong as you may think and you want to drill a hole where it was not engineered for the hole to be. even with that part of the knuckle having more material there, that material is there for a reason, and not to be drilled through for a set of calipers to fit. How often do people have bent control arms because they hit a pot hole and the control arms are pretty beefy. It just seems you are going about it the wrong way here. jizzle85, make a bracket and be done with it. I have a BMW M3 that I converted the stock sliding calipers to brembo calipers from a porsche 911. Did it fit or line up stock for stock....no , of course not, but with a bracket it fits perfect and was a simple install. A bracket is the right way to do this my friend.
also not sure if you did the math to calculate for brake bias but you might want to do that. Do you know what the stock brake bias is?
I would most definitely like to use a bracket, and I'm very much on board with using a bracket. Like I started previously, this is an idea that I came up with and it's just that. An idea. Sure there are better ideas and that's why I'm here. Most things are better planned with cumulative thinking. I definitely wanna stay away from welding the knuckle, and drilling holes. Im working an an idea right now to make a bracket that will mount to the 4 bolts that hold the wheel bearing in the knuckle and that bracket will extend out to the caliper mounting pads on the knuckle. It's hard to get my hands on the car because I work full time and have a 16 month little girl that keeps me plenty busy. So for the time being I'm relying on pictures I have taken and the help of googled pictures to brainstorm ideas. This caliper is physically so big and the S5 knuckle does not have a lot of room to clock the caliper to fit best. I can literally only mount it within the mounting ears on the knuckle so is a tight place to fit something so big. If I could post pictures here, I can easily show you guys what I'm working with. I just don't have the permission from the mods to post pics yet I guess. And I'm not worried one bit or concerned with brake bias. This isn't a drag car,auto cross car or even a canyon racing car. I'm purely doing this for appearance factors. That and I'm bored and need something to do for my own personal tinkering pleasure. My bias might get thrown off a bit, but nothing that I would notice. I am ordering some Hawk HP pads and ECS 2 piece rear rotors on Friday, so whatever bias I might lose, can be made up for with the upgraded parts for the rear.
