Results 1 to 40 of 42
    Feb 08 2013
    2017 Corvette Z06; 2007 Ford F-150; 2004 Honda RC51
    Sammamish, WA
    Could changing oil bet any easier? I can't see how.
    Audi Care expired 10,000 miles ago and today I did the first oil change in the car with my new Topsider Oil Extractor. I'd posted on here some time ago asking about extractors and one of the replies pointed me to the Topsider. Checked it out online and found a couple good YouTube videos, saw that it appeared to be a good product, so I ordered one. Couldn't be happier. I ordered my oil from Walmart, 5 pack of filters from ECS, and knocked out the oil change this morning.
    Ran the car for about 5 minutes to warm the oil a bit. Pumped up the Topsider to pull a vacuum, pulled the dipstick, inserted the tube and started the extraction. It started pulling oil right away but after about 15 minutes I noticed that I hadn't completely released the clamp on the hose so I suspect I doubled my extraction time. While that was going on, off with the old filter and in with the new one. While waiting for the oil extraction to finish, I took the opportunity to check and top off coolant and windshield washer fluid. Finished up the extraction, refilled with 0W40 Mobil One and cleaned up without a drop being spilled. Worked perfectly and I didn't have to crawl under the car.
    If you're on the fence about extracting the oil vs draining it, I'd definitely go for it. That's what your dealership is doing. Also, two thumbs up for the Topsider. Worked really well and feels solid.
    Mike
    2013 Premium +, Monsoon Gray, S tronic, sport diff, B&O, 19" RS4 reps, black on black interior, carbon inlays
    Mods planned: seeing doctor tomorrow about a lead foot prosthetic
    Veteran Member Four Rings GeoJoe's Avatar
    Jun 08 2012
    Q7, Q5, 2016 Porsche GT4, Subaru Sambar, Honda Acty Van and a 2018 Tundra Loooooooong bed
    ATL GA
    Cool review... did you get this one?
    http://www.amazon.com/America-5060-T.../dp/B001445IZ8
    Veteran Member Four Rings 1975audi's Avatar
    Nov 15 2012
    2013 ALLROAD B5 S4
    Ancaster Ontario
    Quote Originally Posted by GeoJoe View Post
    X2
    2007 RS4
    2000 B5 S4 stage 3
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    You could have taken it to a Valvoline oil change franchise! J/K. I think most will get my gist.
    Feb 08 2013
    Sammamish, WA
    That's the one. Well made and it works very well.
    Dec 30 2012
    2008 Gsxr 600 track beast
    Mountain View, Ca
    This is AWESOME!!!!!
    I just had my 35k service done and my dealership Audicare is only going to cover me for one more at 45k. I am looking forward at doing some of the simpler maintenance on my own.
    Mar 21 2015
    Quote Originally Posted by Ernie1060 View Post
    There's a couple good brands out there.
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Listen to this. I did the old normal oil change. And coming from a tech that works on cars day to day. I will be buying the extractor for my 2nd oil change. I did my first one being a cheap ass and didn't want to buy a extractor. But changing the oil the normal way is flat out lame. You make a mess and you have to almost strip the drain plug out to get it to seal right. I won't be taking that drain plug out anymore that's for sure. I will be buying an extractor that is for sure. FTW
    Jul 10 2015
    Yea definitely a nice tool to have, will be picking one up too. Thanks for posting.
    Oct 14 2012
    Empty...for now...
    SE PA
    I performed my last oil change using a MightyVac extractor. It worked great and I actually look forward to doing my next oil change instead of the normal dread. I definitely recommend this method for convenience and cost, considering tat the dealer does it the same way. In fact, when I asked the dealer why the quote for an oil change was so high, the service advisor cited the top-side oil extraction method as the reason that the cost was higher, i.e. because it takes more time than draining by gravity. So instead I paid $100 once for my vacuum extractor and will reap the benefit of doing the job myself in the future.
    SOLD 2015 Daytona Gray S4
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    Quote Originally Posted by SteveYem View Post
    Steve- Did you buy the compressed air model or manual vacuum pump model Mityvac?
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Veteran Member Three Rings MerkurRS's Avatar
    Oct 04 2012
    Four Passat W8's, 2003 allroad 2.7t , Ford Excursion Ltd V10, 1989 Merkur Scorpio, 1987 Merkur XR4Ti
    Berthoud, CO
    Sorry, I am going to buck the system here...I love getting under my car. I enjoy making sure everything is in good shape, clean up any dirt, oil, etc. that lurks below. I get it that extraction is convenient- but something is said for the intimacy of being underneath my car. Maybe its because I have four daughters and 8 dogs that I want to be in my garage as long as possible?
    2012 Audi S4 Prestige Glacier White, Alcantara Leather, Titanium/ Black Optics Pkg, Auto/ Driver Assist/ Drive Select/ B&O/ Carbon Inlays, UltraCharger, APR Carbon Intake, Flat-bottom Wheel, 3G+Google Map conversion, Passport 9500ix red/carbon limited edition, Michelin A/S 3's, Armytrix/ Custom Exhaust, Spulen Diff Mount, 034 Trans. Insert, Eurocode Alu-Kreuz, ACNA Member
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by sacandagaD View Post
    I went with the manual pump version due to not having a good compressed air source. I had to pump it up a few times throughout the process to reestablish the vacuum to keep the oil flowing, so it wasn't totally hands-off. Still better than taking it to the dealer, but had I a good compressor situation I would have sprung for the air powered version for sure.
    Jul 02 2013
    Good to know, now I'm leaning toward buying one. It seems really easy and with a dealer cost of $ 150 to do it, it would pay for itself with one oil change.
    Senior Member Two Rings jmaddr's Avatar
    Jun 19 2013
    United States
    Has anyone used an extractor, then when drained but not yet filled, pulled the drain plug just to see what came out? I'm for the extractor, but not sure it will get everything down in the drain plug area. I also agree with @MerkurRS in that getting underneath allows you to visually inspect many more things than you could topside. Also, if you have a magnetic drain plug it will allow you to remove those shavings to allow more metal to cling. I doubt there will be so much metal that it would lose it's effectiveness but I'm also not willing to test that out.
    Mar 05 2015
    2009 A4 Cab: S-Line / 1996 Camaro Z28
    East Granby CT
    Here's a video of the TopSider in action - and they even point out that using an "Extractor" pulls more oil than the typical drain method - Including examples of an oil pan off the car....
    Topsider In Action - Video Review
    I'm sold - will be purchasing one prior to the next oil change......
    2012 Moonlight Blue Metallic S4 | Premium + | DSG | 19" Peelers |Sports Diff | MMI w/Nav | B&O Audio | Advanced Key |
    After-Market Add-Ons: Rallitek Aluminum Paddles | USP LED Interior Lighting | Phillips Xtreme +50% Headlight Bulbs
    Performance Upgrades: 034 Stage 1 ECU & TCU | | APR I/C |
    Stoptech Cryo Slotted Rotors with Porterfield R4-S Pads |
    034 Springs / Koni Yellow shocks | Tires = Michelin Pilot 4S (255/35/19)
    May 17 2012
    Houston, TX
    Looks like a miniature floor polisher... Lol. I've tried and passed on these. I was one of the unfortunate ones to get a leaky mitivac. Was a huge pain and totally not worth it. Ended up tossing it (I tried two different ones and had same issue both times). Glad this worked out for you guys.
    Jan 14 2009
    pasadena md
    Quote Originally Posted by MerkurRS View Post
    Im with you on this until i did my own and found how much of a pita the drain plug is. The drain plug is garbage on these cars. I like studying the engine but I'll still do it just won't be taking the drain plug out.
    Jul 10 2015
    Quote Originally Posted by AKPS4 View Post
    What exactly was leaking for you, the hose or the container..?
    To be fair the Mityvac has some unfavorable reviews when I was looking up different extractors but the reviews for this one seem solid.
    Jul 02 2013
    Quote Originally Posted by grovlet View Post
    After watching video and seeing a couple of the posts regarding the Mityvac, it looks this TopSider gets my vote due to it's simplicity. Even if you only get one oil change out of it, you'd be ahead.
    Mar 07 2015
    Ottawa, Ontario
    Did you use this one: http://www.amazon.com/Mityvac-7201-F.../dp/B0002SR7TC
    Feb 08 2013
    Sammamish, WA
    It's simple and well made. The vacuum pump and hose assemblies screw onto the can with rubber gaskets to seal them. When you're done, you pull those off and replace them with two caps that come with the kit and now you've got a sealed container that you can take to the auto parts store to dispose of the oil. I couldn't be happier. I spilled zero drops of oil in my garage.
    Mike
    Veteran Member Three Rings Midnight_Rider's Avatar
    Jan 25 2015
    VA
    how many quarts of oil do we need for b8.5?
    C7 Z06 3LZ - AMR Long tube header and exhaust, Halltech Intake, tune.
    B8.5 S4 - Daily commuter. IE Stage 2 ECU/TCU, IE intake
    AP1 S2k (glass rear window) Black with full red interior - all suspension mods - SCCA car
    Evo VIII - AEM EMS, Cosworth Cams, intake, Whiteline front and rear sway bars, exhaust, etc., etc., etc..
    Oct 14 2012
    Empty...for now...
    SE PA
    Yep, that's the one
    Quote Originally Posted by Dazman63 View Post
    Veteran Member Three Rings SouthernBoy's Avatar
    Jun 03 2014
    Virginia
    Quote Originally Posted by Midnight_Rider View Post
    We need 7.2 U.S. quarts for a fill, as memory serves me.
    I did my 2016 S4's first oil change last October when the car had close to 1900 miles on it. I will be doing the next one soon at either 5,000 miles or 6,000 miles.. Haven't decided yet which it will be but probably at 6000 then again at 10,000, and then at every 5,000 miles thereafter.
    I used a MityVac 7400 which is the manual pump version and it worked like a charm. I was very pleased.
    In the final seconds of your life, just before your killer is about to dispatch you to that great eternal darkness, what would you rather have in your hand? A cell phone or a gun?
    Veteran Member Four Rings theswoleguy's Avatar
    Dec 07 2012
    Atlanta, GA
    ordered parts per this post. Standing by for weekend oil change. Probably will do oil changes every 5k miles in between my audicare services.
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, E85, Sold
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, Sold
    '15 Audi S4: Stock, S-Tronic, B&O, NAV, ADS w/ Sport Diff, Smart Key, glacier white w/ magma red, 19" Shamrocks lol
    Oct 02 2006
    Wadsworth,OH
    Below is the oil extractor featured on out instgram page.
    https://www.instagram.com/p/BCqONmFr...n-by=ecstuning
    Jason
    May 17 2012
    Houston, TX
    Quote Originally Posted by bizzy View Post
    It was the hose fittings for both. Couldn't hold any pressure whatsoever.
    Jul 10 2015
    Hm ic, will keep an eye on that when I use mine.
    Dec 10 2012
    New York
    I like to pull my plug every 2nd oil change, just to get any crap that may have settle to the bottom of the pan.
    Jun 11 2014
    Pittsburgh
    ordered an extractor, huge funnel, some mobil 1 euro, filter, and will be doing my first oil change ever. thanks for saving me money guys :D
    1552
    Jun 14 2014
    Liberty Lake, WA
    Quote Originally Posted by nunzo View Post
    Me too! Ordering here soon.
    - - - Updated - - -
    Question - what are you guys doing for your service light reset? Does Carista work or do you have to be in beta?
    Jun 11 2014
    Pittsburgh
    carista works great
    1552
    Jan 28 2013
    Quote Originally Posted by switchedstance View Post
    Do you ever find anything?
    I'd think that's what the filter is for.
    Jun 03 2014
    Virginia
    For the oil fill funnel, I didn't have any that would work without spilling oil on the valve cover and parts below. There is a plastic, or nylon, device that partially covers the opening that you will see when you remove the oil fill cap. Most funnels are not going to clear this and it will block oil from leaving the funnel. You need a funnel with a very wide and short opening to insure that the new oil will clear that impediment and not spill out of of the fill opening.
    So I made one out of a 1/2 gallon milk container. It works perfectly and doesn't spill a drop.
    Dec 07 2012
    Atlanta, GA
    I'm just going to say wow. Having turned wrenches for a living through college and doing my own vehicle maintenance this was by far amazing.
    Sent from my Nexus 6P using Google's ProjectFI
    Veteran Member Three Rings Jv218's Avatar
    Jun 10 2015
    15 S4, 2012 civic
    Boston
    So this pump you have to manually pump it continuously?
    15 Ibis white, Dsg, P+, magma interior, F1 35% pinnacle tint, ECS RS4 grill, AWE Track 90mm tip, 19x9.5inch HRE FF01, ECS Carbon Intake
    Dec 07 2012
    Atlanta, GA
    No pump it about forty times and let it go to work. To get the last couple quarts I had to repump a few more times
    Jun 10 2015
    15 S4, 2012 civic
    Boston
    Quote Originally Posted by theswoleguy View Post
    Gotcha thank you. Definitely ordering one
    Veteran Member Three Rings blingaling's Avatar
    Feb 12 2011
    05 ninja 636(RIP)
    NEPA
    Wow...yup already purchased! Lol i dread oil changes because it takes more time getting under it than draining lol
    Sent via smoke signals
