Alright guys so i ran the c230 rotors for a while with no fitment issues. Recently they felt like they were warped because I was getting pulsation. So, decided to try out a new rotor with less work: the v70r's. With lug nuts bored out and little grinding at the top and bottom of steel upright, I got the driver side to fit with no issues. Put the passenger side on and realized I'd have to grind down the caliper guide pins for the rotors to clear... Ok cool not a problem. Spent an hour testing, grinding, repeating until clearance was made.
Awesome, so I got the caliper bolted up and went to load it with pads.... Not!!! The offset the passenger side has does not allow the outer pad to go in. I know it's not wheel bearing issues as I pressed in front bearings with new hubs. Also torqued the axle nut to spec before doing calipers just to pick up any "slack" and alleviate fitment issues.
Anyone know any suggestions? I think a couple mm washer between the mating surface of the caliper and knuckle would be perfect, but seems unsafe. Anyone done anything similar?
