Results 1 to 10 of 10
    Nov 23 2014
    North Carolina
    B pillar panel molding material?
    So, I'm going to be doing a good amount of paint work to the S4 this week. stripping old wax, clay bar, decontaminate, then several stage wax with Zaino Z5 then Z2 Pro. My question is about the B pillar panels that are black. Are they plastic? painted? I'm not sure if I can get the swirl out with the Z5, and am trying to decide if I should compound them first or not before waxing. anyone deal with them before?
    2021 Glacier White S5 Prestige Coupe - ECS Swaybars, 034 dynamic+ links, ECS tower brace, wheel spacers 12.5f 15r, CTS catted Downpipe, Wagner Intercooler, Andy_FL CF inlet pipe, EPL stage 2 E40 or 034 stage 2 E85 depending on mood
    2019 X3 M40i - Sold
    2015 Sepang S4 Prestige 6MT - sold
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    They're plastic.. You can use a light polish. Compound would be too abrasive IMO.
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Mar 21 2015
    Heres mine with a rock chip
    Aug 03 2014
    Queens
    Did you polish that? If you did what did you use, It looks good.. Except for the chip lol
    Previous
    Mar 21 2015
    Had a full custom detail and Cquartz applied that day in the pic.
    Sep 02 2015
    Durban, South Africa
    You can polish them out beautifully, I have done it many times! And yes they are plastic just go slowly when polishing.
    Senior Member Three Rings RyanJon's Avatar
    Jun 06 2013
    Aprillia SR50
    Oldham, England
    How easy are they to change? I've got a scratch on 1 that I'm sure won't polish out
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by RyanJon View Post
    You could also cover it with gloss black wrap . Cheap but effective repair.
    Mar 21 2015
    I've got a brand new one coated with C quartz ready to be installed. Heard it was a pain so i've been holding off. Can't find any diy on it. There is a screw near the bottom.
    Nov 23 2014
    North Carolina
    Not sure If i'm doing it wrong or I need something more or less aggressive, but I hit them 5 times each with my compound and am not seeming to make it clearer. I'll try something different tomorrow and see what shakes out.
    2019 X3 M40i - Sold
