Results 1 to 4 of 4
    Nov 23 2004
    B5 S4 Built Motor GTX28's
    NH
    Update to my clutch chatter/slipping ordeal..
    Pulled the motor apart this weekend and pulled the clutch. The TOB has indents from the pressure plate fingers, it is not suppose to look like this correct? TOB has maybe 7K on it.
    The pressure plate shows blueing due to what I assume is slipping.
    The pucks on the disk look OK, tbere is some black smokey buildup around the pucks as well. The FW side is considerably more worn down than the pressure plate side but I cant remember what it looked like new.
    Lastly, I haven't taken the FW off yet to inspect the RMS but there is a good amount of oil build up in the bottom inside of the bellhousing so I think there may have been some oil contamination as well.
    Any thoughts?
    B5 S4 Built motor GT28X's
    08 3.2 A3 DSG DD
    Dec 10 2013
    Borden, Ontario, Canada
    That clutch got eaten. Sounds and looks like defective TOB caused premature clutch failure.
    Although RMS leaking shouldn't have had such a drastic effect on the clutch unless it was hemorrhaging oil
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Aug 25 2012
    Elmore alabama
    What clutch is it? Project b5 or clutch masters? I have a brand new clutch kit if you need one.
    Feb 17 2016
    2001 b5 passat stage 3 2.7t swap
    cincinnatti
    Quote Originally Posted by S4tech2 View Post
    What's your ticket price lol
    Sent from my XT1030 using Audizine mobile app
