Results 1 to 3 of 3
    Dec 16 2014
    05' B6 1.8T - Pulley Noise
    So I have 91K on my 05 A4 S-Line 1.8T. The other day I notice at the drive through a loud noise coming from the front end. Upon further inspection the tensioner seemed to be vibrating and jumping. I replaced the tensioner, however it still jumps and now I have a louder noise.
    I took the belt off again to test the alternator pulley. In a fixed position the pulley would not rotate clockwise, however it would rotate counter clockwise with some resistance. I think this is normal.
    It sounds like the PAS is out of fluid but the reservoir is full. My A/C does not blow cold, so I'm wondering if its coming from the A/C pump (which it seems to be) and if it just needs a charge or if it needs to be replaced.
    The noise occurs with or without the AC on and it doesn't start until the car comes to idle around 800rpm. Also the noise is unaffected by turning the wheel. PAS is working great.
    Established Member Two Rings OttawaWill's Avatar
    Mar 02 2015
    Ugly, Boring, Family mover.
    I've never had an Audi alternator in my hand but have had many other and they have always been free of resistance.
    If it were me I'd be getting new alternator.
    Sent from my HTC One_M8 using Audizine mobile app
    Dec 16 2014
    Alternator is good. Idler Pulley is good. $300 later its the AC compressor. $2,200 was what the shop I took it to quoted. Dealer quoted $1,500. Should have her back Thursday...
