Results 1 to 3 of 3
    Nov 18 2014
    Brake Upgrade (S4 B8.5)
    Hi All,
    Brakes are shot and it's time to switch out rotors and pads. Research quickly identified HPS 5.0 pads as a strong option for increased braking power, heat resistance and other measurable benefits. However I'm confused when it comes to rotors. What exactly is it that the usual aftermarket options (StopTech, ECS, Adams, etc.) offer over standard OEM rotors beyond slots/dimples/cross-drills?
    Is there a rotor that offers measurable increases in stopping power and fade resistance over stock, that is not part of a BBK system?
    Established Member Two Rings SimbadCA's Avatar
    May 11 2016
    Audi TT (MK1, 8N) Quattro
    Camarillo CA
    Quote Originally Posted by s42014DSG View Post
    Hi All,
    I would like to know what you decided on the rotors. Thanks.
    Sent from my iPad using Audizine mobile app
    Jul 19 2011
    03 Passat Wagon 4motion, Mk2 Jetta Gli Vr6 Swap
    Bum Rushing Flushing NYC
    Dont mean to jump your thread but im looking for alittle brake upgrade info myself, my problems alil diff i has a 03 Passat wagon v6 4motion and i picked up a set of front RS6 calipers & rotors but i only have the rotors for the rear and from some research im finding out the rears dont bolt up like the front cause of the vented rs rotor and offset. So i wanna know if i can use the rear hub off the a6 4.2 with the rs carriers and rotors and pick up a set of calipers big enough for the vented rotors any help would be greatly appreciated
