Results 1 to 10 of 10
    Sep 11 2015
    Wausau Wi
    Oil in antifreeze overflow tank
    I just did a new head gasket. I have great compression on all cylinders but I have lots of oil getting in the antifreeze overflow( over a quart ). The oil is down but no antifreeze in oil........before head gasket work I had no problems with oil in the antifreeze. Any ideas?
    Feb 24 2004
    Minneapolis
    Oil and coolant are near each other in 3 places: head gasket, turbo and oil cooler. I hate to say it Spencer, but there might be something wrong with your head gasket job.
    Did you get the head shaved?
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Jun 17 2013
    jersey city nj
    Someone ed the head gasket upside down
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by vce1232000 View Post
    Can that be done with this motor vce1232000? I know someone who did that on a Subaru once. I used a whole bag of oil dry to clean up the garage floor.
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by mtroxel View Post
    Sorry aluthman"Adam" the burn cream again this thread will explain
    http://www.audizine.com/forum/showth...+cylinder+head
    Sep 11 2015
    Wausau Wi
    Yes the head was milled. I really didn't want to have to take it back apart.....
    Mar 24 2013
    Oakdale, CT
    SEE! I'm not the only one! OP, it is indeed possible and I have done it. Open the oil fill cap and see if you have coolant in the head. You need to fix it before starting the car again or you can wipe bearings. Anti-freeze isn't a good lubricant.
    The good news is after putting the head gasket in correctly, the car was no worse for the wear.
    -Adam
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by Spenser624 View Post
    Maybe aluthman will fly out there and do it for you. He's done it before.....
    Sep 11 2015
    Wausau Wi
    I just checked and the gasket is not upside-down. I used a hamburg tech head gasket. Could that be a problem?
    Jun 17 2013
    jersey city nj
    at the gasket carefully. Do you an area that wasnt crushed or allowing leakage
