Results 1 to 11 of 11
    Aug 15 2011
    Audi B6 a4 vr6
    LEVITTOWN PA
    Running 1.8t with 6 speed part out come here it run
    Im in bristol twp. Im not separating tranny from motor cause ppl are annoying when they are not able to see things run. So u can come and even drive car. So black car is getting parted and the motor and trans out of blue car or whole car. Blue car has a lien in my name on it so. Let me know.
    Jan 12 2016
    del
    Are those s line door blades on the blue car? If so how much for the complete set? And are they oem?
    Thanks.
    Established Member Two Rings Ultrakd's Avatar
    Nov 15 2015
    Florida
    Headlights available?
    Mar 03 2016
    Tahoe CA
    ecs button available?
    - - - Updated - - -
    esc*
    Mar 25 2016
    Las vegas
    How much for the ecu
    Aug 27 2013
    Philly
    Whoa! right around my parents neighborhood. Hows the carpet condition?
    Aug 17 2015
    '64 VW Type 3 Notch, '66 Type 3 Fastback, '77 Rabbit 2.0L 16v w/ITBs, '84 944, '99 323i
    Evansville, IN
    6 speed trans, shifter assembly, drive shaft, and rear diff?
    Veteran Member Three Rings quattro guy's Avatar
    Nov 30 2014
    06 audi a4 quattro 2.0 6sp
    rockford il
    that's a big ass turbo on that car in the background, u selling that?
    02 audi a4 Quattro 1.8 6sp, milltek exhaust, Motoza e85tune,f21 @26psi,stage 2 ra4 clutch, hyperboost diverter valve, 18z brakes, rear s4 brakes, TR11 FMIC, je pistons,ie rods 2.0 coil convertion kit (best 1/4mile time on stock engine at 21psi 13.4 @101mph)
    06 audi a4 quattro 2.0 6sp, gfb diverter valve, 2.5" test pipe, apr stage 2, r8 coil packs, s4 front brake
    05.5 a4 2.0tq 6sp, r8 coils, motoza e85 tune. S4 front brakes.
    Senior Member Three Rings MoparFreak69's Avatar
    Jan 31 2015
    2005.5 Audi A4 Avant 2.0T quattro
    Boise Id
    How much for just the shifter assembly?
    '03 B6 A4 Avant 1.8t 5 speed (for now) Quattro - Silver
    '05.5 B7 A4 Avant 2.0t 6 speed Quattro - Dolphin Grey
    '05 Chrysler Crossfire 3.2 6 speed - Aero Blue
    Nov 10 2015
    Northeast Ohio
    Set of Door Blades? If you have a set of black ones i'll take those preferably but color doesn't matter. Also if you just have a driver front and passenger rear in black i'd take just those two instead.
    Dec 11 2015
    PA
    Front Passenger Door blade?
