Don't you hate it when a simple job takes 3 times longer than it should?
All I wanted to do yesterday was to flush my coolant but hit many problems along the way;
1) Nipple on the lower radiator hose doesn't do anything....I turn it to the left (counter clock wise) 90 degree and pull out a little bit but nothing came out...Eventually had to just take off that whole hose but it made a mess Am I doing something wrong here? No B7 guide for this but in a b6 guide it says 1) turn left 90 degree 2) pull out a bit 3) then turn 90 degree and pull more. Maybe was I doing it wrong? If I wasn't, doesn't anyone know the part number for this thing? Want to replace it if its broken so I can easily flush my system in the future....Probably a whole assembly with 2 hoses because they seem crimped on there(?).
2) Is it true our engines hold 9 liters or 9.5 quarts (2.37 gallons) of coolant?? My manual says so but that seems like a lot. Of course that is a 50% mix of coolant and distilled water, but even after just pulling my lower radiator hose off only 3 liters came out (0.8 gallons) and my expansion tank was empty. Yes some remains in the block but 6 liters of it (66%)? Can I safely get more out by running my engine until it spits all of it out? I.e car running but lower rad hose still disconnected.
Thanks guys, really appreciate the help!!
