    Feb 20 2015
    Sydney
    Audi S5 roof sun shade removal
    Hi guys
    I have issues with the roof sunshade. How do I get to it?
    From the top by removing the glass or from below removing the headliner?
    Any one knows or any DIY?
    Thanks
    Veteran Member Four Rings SLU_S5's Avatar
    Sep 06 2014
    Rochester, NY
    I remember seeing a write up somewhere about it where the glass only needs to be removed.
    Tilt the sunroof glass up as far as it can go and then remove the trim pieces on the left and right side of the glass.
    Once the trim pieces are removed, there are three torx screws on either side that need to be removed along with one that is located inside the sunglasses holder overhead.
    Once all screws are removed, have someone lift the glass off the roof. Once the glass is removed, you'll have access to the sunroof shade roller.
    2010 S5 Prestige 6MT: B.Black:
    APR: Intake // AWE: Touring + non-res DPs, S-Flo filter // CR-15: Brace // ECS: LWFW, Diff Mounts, SS Brake Lines // Eurocode: AK, Sways // JHM: Tune, Short Shifter // KW: H.A.S. // OEM+: B8.5 S-Line Competition+ Bumper, BO S5 Grille, Ecodes, RS5 BBK, 20" RS5 Rotors// SBC: Stg 2 Daily // 034 Motorsport: Intake Pipe, Trans & Motor Mounts, ACAs // Others...
    IG: @SLU_S5
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
    Feb 20 2015
    Sydney
    Thanks buddy but tilts a few cm's only and the sunshade opens by pushing it forward. US have different specs?
    - - - Updated - - -
    Thanks mate. Hope its as easy as it sounds
    Quote Originally Posted by SLU_S5 View Post
    Veteran Member Three Rings kt883's Avatar
    Nov 10 2010
    Stoney Creek
    any advice for removing the trim clips without that tool?
