Results 1 to 8 of 8
    Active Member One Ring Audi-Buddy's Avatar
    Mar 02 2016
    Northern Ireland
    How big of injectors can I use???
    Hi,
    Thinking of getting bigger injectors for my 1.9tdi 130bhp. I want to know whats the biggest i can get for the 1.9tdi?
    Iv seen 2.5tdi injectors for sale but heard they have a different spray pattern.
    Btw my car is remapped sitting at 170bhp ;)
    Sent from my GT-I9300 using Audizine mobile app
    Veteran Member Four Rings f1torrents's Avatar
    Apr 27 2012
    B8.5 6MT S5 Coupe / B9.5 S5 Coupe
    Guelph
    You cant just put in a bigger injector and think your current tune will work with them.
    You need to get a new tune and have it written for the specific injectors you plan on using.
    VW/Audi keys. MK4-MK5-Mk6-B5-B6-B7-B8-B8.5-TT-A3-A4-A5-A6-A7-A8-Beetle-Tiguan-Touareg- ETC... PM for details
    Cluster Adaptation, ECU Adapting, Component Protection, Module Coding, Immobilizer, Keys Cutting/Programming
    Mar 02 2016
    Northern Ireland
    Can a tune like that be writin in a vagcom if i knew the write setup?
    Dec 05 2007
    No. Info you are looking for should be found here.
    http://www.nefariousmotorsports.com/forum/
    Mar 02 2016
    Northern Ireland
    Thanks, just looking to educate myself on the options i have first.
    Dec 19 2011
    Colorado Springs
    Convert to Return fuel and not need massive injectors.
    Or at least not AS big as you would need with returnless.
    I plan on 1200cc injectors for my build..@4bar w/ a rising rate. so Probably make them behave like 1350's or so. I dont care to do the math right now.. Note its a 3076, built motor on E85.
    '12 GLI EFR 7163 - '16 S3 IE Stage 2
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Quote Originally Posted by B6A4Dave View Post
    He has a 1.9 TDI. Totally different animal. TDI's run fuel injector pressures up to 27,846 psi (192,000 kPa / 1,920 bar).
    Clicky click®
    Dec 19 2011
    Colorado Springs
    ooooh!! Must've missed that haha.
    Thanks Fletcher :P
