Originally Posted by
Nollywood
1. Everything bar the facelift micro-switch release pads can be fitted to Euro pre-facelift ('96 North American) trunks, as well as '97 onwards North American trunks. Just need to drill some holes, bend a few rods and use the
2. Euro facelift trunk harness (it is a separate loom).
3. You will also need the facelift Euro central locking pump.
Though it will all work just fine, I would locate and use the facelift Euro trunk lid. It just looks so much nicer
1. The lock isnt a direct oem fit, more hacked together.
Decided to use the stock lock and bent some welding rod to connect it. Gona drill two 3mm holes for the solenoid.
2. Where does the harness separate? On the pump itself?
3. I just programmed the 3 button fob from a facelift euro key to my car. Haven't hooked up solenoid, but lock unlock works. I read somewhere there was some pumps had the output for the solenoid just need to wire up? Another plus was the 3 button had more range, 2feet more. I now have 7feet of range.
4. I'm 50/50 on this. I like the plate recess and key hole of the facelift, but i like the the swage lines of the prefacelift. I already have the facelift, just thinking if its worth the trouble of painting it over keeping the current preface trunk.
Facelift = cleaner
Non facelift = more character?
