Results 1 to 11 of 11
    Active Member One Ring Rody_C's Avatar
    Mar 04 2016
    San Diego
    Swap keyfob shells
    Hi, i bought a new keyfob shell in ebay, i would like to swap all the internals include the chip and the blade from my key,
    i see a post and a member say it wont work because the little glass that turn red when you press a button, he say is coded,
    and made for that specific car.
    Is this true, anyone has done this before?, Thanks
    Veteran Member Four Rings Schweini's Avatar
    Sep 12 2011
    2011 GTI mk6 DSG
    Hamilton Ontario
    Sometimes if I stare at my car long enough, it unlocks itself
    2008 A4 S-line 2.0T
    JHM Stage 2
    Feb 24 2004
    Minneapolis
    Yes, it's doable. Bring the board, immobilizer chip and the metal key. See this DIY
    http://www.audizine.com/forum/showth...Fob-for-B6-DIY
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
    Veteran Member Four Rings 2pointOh's Avatar
    Dec 08 2013
    Buffalo, NY
    So if you swap the blade, board, and chip over to a new fob, you're good to go, no programming right? I need to renew my fobs, both are looking worn, and replacing the buttons never feels right (cheap Chinese shit)
    2006 A4 2.0T 6sp. JHM Stage 2 93 Oct. JHM TP-DPY to S4 Exhaust. GFB DV+. AFE Dry Filter Drop-In. 034 Engine Mounts. ST Coilovers. ECS RA4 LW SMFW and RS4 Clutch.
    Feb 24 2004
    Minneapolis
    ^^^^Yes^^^^ If all you leave behind is the plastic, why wouldn't it? The immobilizer coil can't talk to the plastic.
    Mar 04 2016
    San Diego
    Quote Originally Posted by mtroxel View Post
    Thanks mate
    Dec 08 2013
    Buffalo, NY
    Haha that's what I was thinking but I needed confirmation.
    Quote Originally Posted by Rody_C View Post
    Thanks mate
    Where did you find the new fobs?
    Mar 04 2016
    San Diego
    Quote Originally Posted by 2pointOh View Post
    Ebay
    Senior Member Two Rings drmonkey's Avatar
    Sep 04 2015
    Clear Lake, TX
    I did this on my old MK5 Jetta key and ended up busting the chip trying to get it out of the fob. That cost me $300 as I had to have it towed to the dealership, they had to order a new cut key with the chip, and then program the key to the car (I only had one key to that car). All that because I wanted a newer looking keyfob housing...
    Those chips are usually epoxied in and are very difficult to move. You can find the chips online for roughly $10 but you still have to get it programmed at the dealer. So be careful when doing it and don't force it in any way.
    Disregard this...Apparently the Immobilizer chip is in it's own plastic housing so you don't have to "pop" it out...you just move the little plastic housing to the new key fob...
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by drmonkey View Post
    This:
    Mar 04 2016
    San Diego
    Hi everyone, i just want to let it know that it work perfectly, thanks for the help
