Results 1 to 2 of 2
    Jul 18 2014
    Indianapolis
    2003 A4 1.8t Quattro Manual Transmission with Extensive Mods. - No Longer Available
    Up for Sale is a 2003 B6 A4 1.8t Quattro Manual Tranmission with Extensive Mods with 162K. Called ?Amy? by her old owner, which was an Audizine fan (as you can tell there is an Audizine decal on the car). Below you can see the modifications and maintenance done on it all ready.
    Work previous owner did:
    Please See this google doc: https://docs.google.com/spreadsheets/d/1Wh0SWW9R2csqpnKUfnvUpveOBLizvD0DOKds5Wj68Mg/pubhtml
    Work current owner did:
    140K ? Resealed power steering line leaks; Replaced lines and jets on the windshield washer system; Replaced timing belt tensioner, pullies, timing belt, and serpentine belt tensioner. (All done by Euro Motorworks)
    144K ? New Momo 17? rims with Continental Extreme Contact DWS tires 235/45 R17 (Done by Discount Tires)
    146K ? Replace oil pressure sensor and sensor harness; Replace oil pan gasket; Replace oil pick up (All done by Euro Motorworks)
    157K ? Replaced Passenger CV Axle (Autobahn Service Center); Replaced coolant flange on back of head (Jeff?s Volkswagon Repair)
    The Audi drives wonderfully and in my driving gets 25 mpg combined. No Engine hesitation or issues with the transmission at all.
    Spare Parts included in sale:
    1. S4 Rear Bumper (needs painted)
    2. Old turbo (deconstructed and quoted as needing a new core)
    3. New set of Zimmerman front brake rotors with Hawk Performance Ceramic Brake Pads (front) (Rears where just replaced with same set of rotors and ceramic pads)
    4. New driver side CV axle
    5. RossTech VCDS cable; Motoza cable.
    6. Other Spare Parts
    The Issues:
    1. There was an incident that with a loose piece of tire tread on the interstate that got imbedded in the lower passenger side bumper where the fog light resides. It ripped out the mounting for the fog light and the grill around it. Will need a new front bumper. (See picture)
    2. There is a windshield washer leak under the front driver side headlight washer. This prevents the washer reservoir from filling up with anything past a couple drops. I believe with the aforementioned tire tread incident that it also pulled the tube going to the passenger side headlight washer and caused it come decoupled on the driver?s side. Probably an easy fix when the bumper is replaced. Had no issues (and recent replacements of system) with the windshield washer system before the incident.
    3. Ongoing ?Loss of power? issue. This has been an issue since I bought the car a little over a year ago. I have gotten it to the point where it will produce up to 6 or 7 psi, but according to the Motoza tune, it should be producing 20 psi (not sure how accurate that is). The valves (N75 and Diverter) were replaced right before my purchase of the vehicle. The turbo was also replaced with a used, but good, turbo right before my purchase. I had a smoke test done and there are no leaks in the system. Not really an issue, it just produces a dash-board light (which is the only fault in the system).
    4. Airbag light is on, from what I have researched this is most likely due to a loose connection under the driver?s seat.
    5. Rear bumper has two holes in it. I was given a S4 bumper with the purchase. S4 needs to be painted, then good to mount.
    Reason for Sale:
    Found I don?t have time to keep this baby up to spec anymore, so I want to sell it to someone who will keep her going, because she has a lot of life left in her.
    Please don?t hesitate to ask any questions! Price is Negotiable.
    List Date: 3/5/2016
    For more info, click here to view the original listing: 2003 A4 1.8t Quattro Manual Transmission with Extensive Mods.
    This item is no longer available.
    Senior Member Three Rings hihosilver's Avatar
    Mar 09 2008
    2003 a4 1.8t
    Boston, MA.
    Interior color/trim?? Pics??
