I just want to check to see if my coding matches.
I get a malfunction for both so I wanted to compare the coding.
Thanks
Here are my scan info for both
Address 15: Airbags (J234) Labels: 4F0-910-655-10.clb
Part No SW: 4F0 910 655 R HW: 4F0 959 655 H
Component: Airbag AU1042 H06 0160
Revision: -------- Serial number: 003FA0010M7F
Coding: 303142373034303030314A55304C34463053
Shop #: WSC 19502 444 84312
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 3620EAB689814E8E94-8062
Seat occupied recognition:
Subsystem 1 - Part No SW: 4F0 910 339 B HW: 4F0 959 339 B
Component: BF-Gewichtss. H03 0060
Serial number: 5810000R0000003JM3
Coding: 000000
Crash sensor for side airbag; driver side:
Serial number: 3574SRB4000094CCD16H
Crash sensor for side airbag; front passenger side:
Serial number: 3584SRB4000094A92ADI
Crash sensor for side airbag; rear; driver side:
Serial number: 3516HRB402R9ICPJ045N
Crash sensor for side airbag; rear; passenger side:
Serial number: 3526HRB402T9DVI0VKN-
Crash sensor for front airbag; driver side:
Serial number: 3554NRB400004FC6BE7M
Crash sensor for front airbag; front passenger side:
Serial number: 3564NRB400004EDB86EO
1 Fault Found:
12583424 - Powertrain Databus
U0002 00 [008] - No Communications
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 2
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4F0 035 082 A HW: 4F0 035 082
Component: Radio U SIRIU H45 0021
Revision: AB001007 Serial number: 335GS097521137
Coding: 020000010000000000
Shop #: WSC 02391 823 56573
VCID: 1D72151A0477FDD675-8048
1 Fault Found:
02788 - Internal Communications Error
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 185
Mileage: 121111 km
Time Indication: 0
Date: 2015.02.09
Time: 09:00:46
Freeze Frame:
Bin. Bits: 0000000
