Results 1 to 14 of 14
    Veteran Member Four Rings Danaldson's Avatar
    Aug 28 2014
    Calgary, Canada.
    Teach me how to Aftermarket Seats.
    Hey guys, have a few questions on running aftermarket recaro's in a b7.
    I know the oem seatbelt is attached to the base of the seat... would there be a way to work around that?
    Airbag/Occupancy sensors, I there a way to clear codes, or disable them somehow?
    The seats in questions are Recaro SR3's (from an evo4 i suppose).
    Any help appreciated thanks.
    Nov 15 2011
    Montreal | I sell in USD
    You can code a Canadian* B7 seat occupancy like a B6. Side curtain will deploy even if no one is in the seat in case of an accident. (The passenger seat would too but you wont have any)
    You can put a resistor on your floor airbag connector to trick it into thinking its there.
    * Cant be done on a US car.
    *****I sell in USD*****
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    You just bolt the seatbelt to the floor or seat bracket. I don't recall which, but that's not an issue. The passnger occupancy sensor, as metioned, is.
    Quote Originally Posted by Axis View Post
    I wonder, could one just buy a Canadian airbag module and install that? They are cheap if I recall correctly.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Aug 28 2014
    Calgary, Canada.
    Quote Originally Posted by LINDW4LL View Post
    Ahh okay thanks guys! The seats aren't the best looking, but it would be nice to have some beefier bolsters for the summer, the swap the stock ones back in the winter.
    The recaro's currently have red plaid inserts, with black alcantara like material on the bolsters. I would probly like to re wrap them in a leather to make them a little more luxurious.
    Dec 10 2011
    CLT | MKE
    How much are said Recaros?
    -Hayden
    Mar 24 2013
    Oakdale, CT
    I wouldn't think it would be all that hard to add a B7 occupancy sensor to aftermarket seats, especially if you're recovering them. You could also try just adding the control box for the sensor and a resistor to simulate a bladder connected to it.
    -Adam
    Nov 15 2011
    ^^The Canadian occupancy is so thin it could be retrofitted easily.
    I have a spare one with proper seat harness and seat belt buckle if interested.
    Aug 28 2014
    Calgary, Canada.
    I have the chance to grab these for just over 500 bucks for the pair.
    I'm still not 100% sure they would look good in the car though.
    Jun 27 2011
    You can get a pair of actual S4 recaros for $500. And not have to modify them in any way. Why would you spend that money on those?
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Veteran Member Four Rings onedumslack's Avatar
    Mar 05 2014
    phoenix/az/usa
    Where? I've been searching for a few weeks and don't find cheaper than $900+shipping.
    Jun 27 2011
    Uhh, I found a full front and back set on ebay in good condition no less for $900 + $180 shipping literally last night after I posted that. Just the fronts you can for sure find for $500
    -CP
    2017 Q7 3.0t
    Mar 05 2014
    phoenix/az/usa
    I see. I was looking at that same set and thought you were referring to a full set.
    Jun 27 2011
    Quote Originally Posted by onedumslack View Post
    Hah. If you found a full set for $500 that would be the deal of the year!
    -CP
    2017 Q7 3.0t
    Aug 28 2014
    Calgary, Canada.
    I really doubt I could find oem seats for that much around my parts. I haven't seen a set pop up so I'm kinda looking at other options.
