Most are used, but a few are new - well not brand new, they've been sitting in my garage for a few years so i'll mark those as "UNUSED".
Located in Dallas, TX area so willing to meet for local transactions.
USED - THREE A-Box ECU's (551 A)
$300 - 1x GIAC X Flashloader compatible
$250 - 1x unknown stage 1 (from salvage puller, confirmed functioning at stage 1 boost around 16-17psi)
* note, One of the GIAC boxes also has an XR program, but I forgot to mark the boxes so I don't know which one. Consider it a surprise bonus. Other ECU was marked by salvage guy as seen in pic.
UNUSED - DesignIt Engine Mounts - never installed, $225
USED - 1x Bosch 710 B Diverter Valve - $15
SOLD - 1x Bosch 710 N Diverter Valve - $15
UNUSED - Aerocatch Flush Hood Pin set model 120-2000 - $50
SOLD- Audi Rings, for trunk lid $10
USED Samco f-hose, blue, well under the engine grime its blue - $20
USED - AWE Birds-Eye maple, red illuminated shift knob - excellent match to OEM trim (minus the connector that splices into cig lighter power, so you'll have to rig your own) $125
USED - 6x Bosch Platinum F5PD0R - $50
(~500 miles IIRC, then had misfires that were traced back to bad ICMs, but had plugs swapped anyway during diagnostic)
SOLD- AWE Downpipes (includes hi flow race cats AND test pipes)
Found an FCP Groton front LOWER Control Arm Kit (was a full kit but installed the uppers (unless I just got that backwards and these are the UPPERS?, was going to check my car then realized I sold it 3 years ago :/) - $150
no pics, but if someone is interested I'll get 'em for you.
SOLD - Audi OEM mudflaps - $50
USED - 1x throttle body, 2x EGT sensors, 2x O2 sensors (TB works, sensors unknown condition), OEM shift assembly (taken out for short shifter), A-pillar pod, VDO boost gauge - best offers
USED - OEM front grill (for hood) - $40
