My engine is out right now to do the timing, and while I was standing in the engine bay checking things out I noticed that my steering rack has a leak where these small pipes connect to it. These aren't the pipes that connect to hoses or circulate fluid through the system, they just connect from one part of the rack to another part. Looking at the parts diagrams, these pipes are shown as being part of the rack - they are not listed as separate replaceable parts and the exploded view doesn't explain how they seal to the rack.
not sure if you can see it in the photo but there's a bit of an oily mess around that threaded connection.
this end of the pipe is also leaking as you can see much more clearly from the pic
My question is, does anyone know if these connections use any kind of seal that I can replace, like maybe an o-ring or crush washer? any other suggestions/advice is welcomed
