Results 1 to 26 of 26
    Established Member Two Rings Durk's Avatar
    Oct 12 2015
    Pittsburgh
    Looking for suspension advice on springs / shocks / struts
    Hello,
    Let me preface this by saying I have searched and searched and searched on these topics. Looking for some fresh insight. A thread from 2009 doesn't have recent options.
    Also I'm not doing coilovers. Not an option. My only suspension mod is the 034 Rear sway bar. Going to get a beefed up front sway bar when I do my front.
    My S4 has 94K on the completely original suspension. It's toast. The back sags, front control arms creak, every bump is jarring.
    I have a set of used lower mileage RS4 springs (which are the same I understand) that I could swap in. I also purchased the rear refresh kit from ECS as I want to tackle the rear of the car first since it is in worse shape.
    Option 1: Use the better condition springs and pair with shocks struts.
    Option 2: Go with Vogtlands (decided after much research) and pair with shocks and struts and sell the RS4 springs.
    I really wish someone made a stock ride height performance spring. I've searched high and low and cannot find anyone that does. Is this because the stock S4 springs are good enough no one bothered to improve?
    I live in PA and the roads are shitty. I'm not a lowered car kind of guy.
    I used KYB shocks/struts in my GTO and was happy with them. But the info on the forum is KYB sucks for these cars or people have had bad experiences. I take that with a grain of salt. A shitty car is a shitty car regardless of the shocks you use.
    What do you guys suggest as far as a good DD setup for shocks and struts? I want this to be one and done and address the whole suspension and move on to other areas. I also realize you get what you pay for but I don't want to drop major doll hairs on a daily driver.
    Mucho thanks in advance
    2005 Silver S4 B6 TIP
    Jan 30 2007
    2014 Lexus IS350, 1988 Porsche 944, 2008 Porsche Boxster, 2001 Audi TT Quattro
    Greenville, SC
    I replaced my shocks and control arms at 70k miles and now i have 85k.
    I went with Koni Yellow's with stock springs. Tuned the shocks at 3/4 turn from full soft. If i had to do it over again (and i still may) I'd tune them to 1 to 1 1/4 turns from soft. They're very comfortable but slightly too much float for what i'd ideally like. I only use the car on the street and so I looked for a good combo of comfort and handling. (Both improved relative to stock).
    I replaced all the front control arms (and tie rods) with Meyle HD's. So far, after 15k miles, no cracking nor issues.
    Good luck.
    Tom
    2014 Lexus IS350 (present), 1988 Porsche 944 (present), 2008 Porsche Boxster (present), 2001 Audi TT Quattro (present), 2006 Audi S4 (past), 1998 Audi A4 (past), 1975 Audi Fox (past)
    Oct 12 2015
    Pittsburgh
    Thanks for the reply.
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    I asked a similar question a few months ago as well. Although mine kinda got derailed into some coilover discussion, I am now in the same boat as you wanting just a DD setup/refresh, not coilovers. Maybe some info in here that helps, maybe not, lol
    http://www.audizine.com/forum/showth...efresh-Options
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Veteran Member Three Rings jr1415us's Avatar
    Mar 08 2011
    Chicago IL
    Here's a pretty thorough discussion of Koni and Bilstein dampers paired with stock springs:
    http://www.audizine.com/forum/showth...ght=koni+sport
    2013 Arctic White Allroad Premium Plus
    RIP 04 S4 Avant 2012-2017
    Veteran Member Three Rings JayDog747's Avatar
    Mar 10 2010
    2007 S4,2015 Silverado,2023 WRX
    WI
    Unless you're hauling ass, and by that I mean three fat chicks in the back, you shouldn't need to replace the springs. It is more than likely the pads that the rear springs sit between are shot. Especially the lower one. And while you're back there, you should replace the rear upper control arm bushings. They wear out the same as the upper front. It's cheaper to just have them pressed in than to replace 'em.
    As for the front control arms, IMO, I rank them as Lemfoerder, Meyle HD, 034 and the rest. I have used all three and if you can swing it go with Lemfoerder, otherwise the Meyle.
    There are really only two options for shocks. Bilstien sport are more comfortable than stock and work well at above highway speeds. And Koni, which you can adjust to your liking. You can't go wrong with either one and they are roughly the same price. I highly recommend 034's upper strut mount bushing. It's a nice chunk of rubber and really makes the shock perform at its best.
    Just a reminder, if you replace the front sway bar with a larger one, you will bring back understeer that the larger rear bar took away. Just replace the sway bar bushing mounts.
    If you can you should replace both the front and rear at the same time that way you only have to pay for an alignment once. Oh, and good luck with the pinch bolt.
    Veteran Member Four Rings JimmyBones's Avatar
    Apr 03 2010
    Northern Virginia
    JayDog747 said everything that I was going to except that I would also replace the rear tie arms too. They are cheap and easy to replace. I am a Bilstein fan so I would go with Bilstein shocks instead of Konis.
    You can also use FCP control arms and there is a group buy in the specials section on this site.
    Jul 13 2014
    1997BMWZ3
    Daly City,CA United States
    If you want a comfortable daily driving car and on a budget, I would get the bilstein touring class. I live in the city so I need maximum comfort through potholes and cracks on the roads. http://www.rockauto.com/en/catalog/a...+absorber,7556. Rock auto has the front and rear set for around $220. I installed the rear shocks already and they are great! If you want better steering and less body roll, get the 034 rear sway bar. https://www.fcpeuro.com/products/aud...oAsaAn-g8P8HAQ. 4 shocks with 034 rear sway bar is still cheaper than koni yellows.
    Mar 10 2010
    WI
    Quote Originally Posted by kevinye77137 View Post
    The S4 uses progressive rate springs. Bilstein touring class is not designed to work that type of spring. They are going to wear out more quickly. Also if you reread his post, he already has 034's sway bar.
    Oct 12 2015
    Pittsburgh
    Lot's of great info. Thanks for the responses.
    As far as the sag, it is probably blown out pads. It is so bad though I took the spare tire out. With the springs coming out to replace the upper and lower pads, I might as well through in the other springs with less mileage.
    Based on this info and some research I'm thinking of:
    Bilstein sports
    Lower mileage oem sport springs
    Density line strut mount
    FCP Control arm kit if the group buy is still happening
    Rear upper control arm bushings
    Rear tie rod ends
    Thanks again for the helpful advice, I feel comfortable and confident pulling the trigger on grand worth of parts.
    As far as the front, I have a buddy that is a Toyota tech. Hoping to get in on a Saturday and him lend me a hand with big boy tools.
    Feb 18 2014
    Arizona
    Audi uses different colors and #'s of paint stripes to differentiate between different types of springs. You might want to double check the paint markings on the lower mileage springs to be sure they are the same
    Oct 24 2015
    Perth, WA
    I have the sport suspension as stock, so looking at these Eibach Bilstein B12 Fahrwerk Sportline.
    Anyone got any views?
    My respray thread
    Mar 31 2014
    KY
    Okay I am confused.
    What is the difference in this:
    https://www.fcpeuro.com/products/aud...-rs4-be5b981h0
    and this:
    https://www.fcpeuro.com/products/aud...4-s4-19-164472
    They both say for 2005 S4. One is "Bilstein Sport 8E0413031CP" and one is "Bilstein 8E0413031CP".
    The (part?) number is the same but one is described as "sport" and the other one isn't? Wouldn't that change the number 8E0...?? They are $70 price difference!!
    Oct 12 2015
    Pittsburgh
    Quote Originally Posted by Okedokey View Post
    This is classic example thread jacking sir.
    - - - Updated - - -
    Quote Originally Posted by badger. View Post
    Okay I am confused.
    and this:
    It looks like they messed up and duplicated the part #. The blacks are the touring and are cheaper.
    Senior Member Three Rings hkdolphins's Avatar
    Dec 03 2014
    Noggy Avant, B8.5 Allroad
    SF/CA
    Okay I am confused.
    and this:
    I think(FROM desc) the Yellow one is for Avant and Black one is Sedan(it show does not fit my avant). Also it made from different countries
    B6 Noggy Avant, B8.5 Allroad
    Oct 12 2015
    Pittsburgh
    Quote Originally Posted by 2004B6S4 View Post
    One step ahead of you but mucho gracis :-)
    Oct 12 2015
    Pittsburgh
    Here is a question:
    Why are the tie rod end links beefier for the A4?
    http://www.ebay.com/itm/REAR-TIE-ROD...23AiCA&vxp=mtr
    S4:
    http://www.ebay.com/itm/2004-04-AUDI...9TPEgJ&vxp=mtr
    The S4 are stamped and have holes. The A4 have the thicker side and no holes. It looks like the are the same part. Use the A4 link?
    Mar 31 2014
    KY
    Quote Originally Posted by Durk View Post
    Did some digging, on Bilstein's website:
    >>The black ones (cheaper) P/N 19-164472 are Series B4, described as OE Replacement (original equipment).
    Bilstein B4 OE Replacement Series gas pressure shocks and struts are specifically engineered to be the best choice for maintaining the original ride quality of your vehicle, while meeting or exceeding OE standards. These dampers are the ideal choice for the driver looking to restore the original performance and handling of their vehicle, with the added benefit of world-famous Bilstein quality.
    >>The yellow ones ($$$) P/N 24-119818 are Series B8, described as the Sport version.
    Bilstein B8 Sport monotube shocks and struts deliver absolute mastery of the road surface for the performance-minded driver. Designed to push a car's suspension to its performance peak, these shocks are specifically suited for use with special lowering springs in combination with anti-sway bars or other suspension upgrades. (yellow paint, steel body)
    From that, it seems the black B4s are basically an OEM-equivalent, while the yellow B8s are an 'upgrade' and better suited if you want to do any other suspension mods.
    Quote Originally Posted by JayDog747 View Post
    JayDog, can you expand/source your comment on the "touring class"? From what I read it seems that the black ones are OK, they pull up as matching fit for a B6 S4 Sedan. I didn't see any mention of "Touring" with them. Are they truly an ineffective option for a B6, even when all other suspension components are stock or equivalent? Because I've seen nothing other than your comment to indicate they are in fact improper. Just curious.
    Oct 12 2015
    Pittsburgh
    I'm coming up with part #'s for the rear tie rod ends.
    8E0501529G, K, and P. It looks like the beefier rods were early and then revised to the weaker stamped ones. Not sure if it makes a difference at all, but I might as well throw the beefier part on it.
    I'm going to get this stuff in advance and a set of LCA's off ebay and get the bushings pressed into. That way when I do this job I have the new ones already to be swapped in.
    Mar 10 2010
    WI
    http://www.bilsteinus.com/uploads/tx...uide308_10.pdf
    Page 2. The guide does state you can use the B4 but the B8 version more closely matches the spring rate of the S4. On the Koni website's FAQ it stated having a higher spring rate matched with a softer shock will wear out the shock quicker.
    Mar 31 2014
    KY
    Awesome, thanks for the follow-up! Much appreciated.
    Mar 31 2014
    KY
    Couple questions for anyone who might know re: suspension parts.
    1. Do I/should I need to replace the Front spring perch? Do new struts come with that or would I need to re-use the old ones? (P/N 8E0412066B)
    2. Do I/should I replace the rear Upper and Lower spring perches? Do these go bad? (top: P/N 8E0512149P and lower: P/N 8E0512297J)
    Mar 10 2010
    WI
    Front: The Bilsteins will come with a new perch but not the rubber piece the springs sit on. As for the rear pads, the lower one takes most of the abuse. So you're more than likely replacing that one. The upper one is more... eh... it's up to you. I replaced both. Keep in mind that it will raise the rear end slightly until it settles.
    Veteran Member Four Rings Silver Streakin's Avatar
    Mar 05 2004
    B8 S4, 17 Expedition EL, 2009 328ix coupe
    NoVA
    FWIW, the front B5 S4 spring perch is bolt in and will lower the front slightly. I forget the exact number...somewhere around 1/2" to 5/8" lower than stock.
    2011 S4, 6M, BB/panda, Sport diff, ADS, B&O | UniTronic stage 3 Dual Pulley | MercRacing HX | RocEuro intake | AWE Track & DPs resonated | H&R c/o w/Bilstein B8 rears| 19" VMR 710 & 19" Peelers | 034 trans insert | AK brace | CR15 bar | DEVAL CF Diffuser
    SOLD 2007 S4 DTM, Phantom Black Pearl, manual | JHM | FI | H&R | VMR | 034
    RIP 2001.5 A4 1.8TQMS, Silver/Ebony | APR stage 3 | STaSIS Tracksports | StopTechs
    SOLD 1995 90
    Oct 12 2015
    Pittsburgh
    So I did the rear swap two weeks ago. When I finally sat the car down, there was even a three finger fender gap b/w the front and the back. I was happy. The bottoms were pretty much toast, I did the tops since I had them but like it was mentioned above they could have went back in.
    After driving it, I could tell I was starting to go back to a negative rake. I checked today and I guess it wore the pads in because it's back to three finger front 2 finger rear (no jokes).
    Totally disappointed to be back at square one.
    I can't stand driving this car with the negative rake. It feels odd driving and isn't handling as well I as I feel it should. I did this same surgery on my GTO after I got it because it had the classic saggy GTO rear, and it made the car so much better to drive. I was hoping for a similar result.
    I read before that the B5 perch mod doesn't work with billies. Do you think I could still do it and just enlarge the hole in the perches to match the diameter? I've never seen either part in person.
    [/URL]
    Oct 12 2015
    Pittsburgh
    I looked up the perch I see how it doesn't fit. I have things to think about.
