I just looked and half of the updated threads are companies with more than one thread bump. Can we clean this up?
SUSPENSION-KW V3-Hotchkiss RS4 sway bars-034 Adj UCA-034 strut mount-034 F&R end links-034 motor mounts-034 Snub mount W/bracket-034 Trans mount l BRAKES-ECS Stage 4 BBK-ECS rear rotors & lines, Hawk pads l Engine-JHM Tune-JHM 6 rib pulley-Milltek catless DP's-FI exhaust l EXTERIOR-RS4 black grille-Custom headlights-LED city & DRL lights-ECS LED tail lights & plate lights l INTERIOR-Custom steering wheel-SRP pedals-ECS LED lights-MOMO shift knob-Gen 2 RNSE & AMI l WHEELS-OEM RS4 W/ Michelin PSS
Hugh
EuropaParts.com, Your Trusted Audi Parts Source
Facebook: Like Us on Facebook
Instagram: Follow Us on Instagram
- B7 avant, 3.0t swapped
- B8 S4, Stage 2+
- B6 S4, not stock
- B5 S4 Clone, built motor, 2871r
2004 Black RS FAUX B6
JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
Insta: luccamentone
Forget the B8, keep the V8!
PREV: '99.5 A4 1.8T Avant | '03 GTI VR6 | '06 A4 2.0T Avant | '09 A4 2.0T | '12 A6 3.0 TFSI | '08 TT 2.0T Coupe | '14 SQ5 | '15 S3 | '17 Macan GTS | '19 A7
CURRENT: '95 Ur S6 Avant | '22 Q5 e
Brandon @ VMR Wheels
[email protected] | 714.442.7916 Ext 108 | www.velocitymotoring.com| Instagram | | | Blog
[email protected]
Audizine - "For All Things Four Rings"
• Instagram: @audizine
• Twitter: @audizine
• YouTube: /audizine
• Merch: store.audizine.com
[email protected]
