Results 1 to 17 of 17
    Senior Member Three Rings TheRedGlacier's Avatar
    Oct 31 2015
    1994 Firebird Trans Am GT 6MT
    New York
    Light bulb issues 2001 A4
    Hey guys, I have recently been having issues with the passenger lower taillight bulb. It used to tell me the brake light was out, and sure enough it would be, if I wiggled it, it would work again until the bulb holder would move. But a couple of weeks ago, it went out and I can't get it to light up when sitting.
    Every time I use the lights, I get an annoying beep. The brake light function of that bulb works, which is strange... But the idle taillight doesn't work, so I have to run the fogs/secondary lights so I don't get pulled over at night. I have checked for corrosion in the socket and there isn't any.
    My second problem, is that up front on the passenger side, the parking light bulb doesn't work, but the passenger turn signal does. This isn't as big of an issue to me as the brake light bulb, but I would still like to correct this if I could.
    Thank you in advance!
    The car is a 2001.0 A4 1.8TQM Sedan
    Established Member Two Rings Eddie_b5's Avatar
    Sep 24 2015
    2001 Audi A4
    New York
    Same problem but a little different
    Eddie_b5
    Dec 03 2014
    1999 Audi A4 Quattro Avant 1.8t 1998 BMW 328iC 1986 BMW 528e
    United States
    Up front, are these dual filament lamps? If so, your likely problem is one filament is toast. Replace the bulb.
    My cars
    1998 BMW 328iC
    1986 BMW 528e
    Oct 31 2015
    New York
    Okay, they are dual filament. I feel really stupid now.
    I should probably mention that the taillight I have swapped around, and used singular and dual filament that I know work. Does one filament control the taillight, and the other control the brake?
    Established Member Two Rings volkswagensRus's Avatar
    Nov 19 2015
    Buffalo, NY
    YOU CANNOT USE SINGLE FILAMENT BULBS IN AN AUDI.
    Sorry for all caps, but I was chasing my own dick for MONTHS only to find out that numerous issues across the ENTIRE CAR were simply related to ONE single-filament bulb in my tailight when they should all be dual filament.
    2001 Audi A4 Hibiscus Red Pearl Metallic , quattro, 5spd, Symphony stereo, winter package, 3" 034 catless DP, 2.2" exhaust, white snub nose mount.
    For Sale: 1x oval Borla muffler + piping. 1x rectangular Borla muffler + piping. 1x B5 A4 cat+o2 sensor + wiring.
    FOR SALE: 2 catalytic convertors (one w/ both o2 sensors), Audi B5-a4 cat-back exhaust Borla muffler+resonater
    Oct 31 2015
    New York
    Really? The whole light system can be tricked with just a single bulb being a single filament?
    I'll be sure to swap the three out that are single filaments that the previous owner used.
    Nov 19 2015
    Buffalo, NY
    Yes.
    Get this. When I had a hidden single filament bulb in my rear drivers side TURN signal.... my 3rd brakelight would be on 24/7, but only when the running lights were on. When I hit the brake pedal, it would get darker. When I hit the brake pedal, the front drivers side TURNING LIGHT would come on. Then randomly I'd be driving and the BRAKE light would illuminate on the dash.... sometimes it would even start flashing. All because a single filament bulb was used.
    From what I understand they are dual filament bulbs because they are two systems running through there; the running lights and the turning signals. If you use a single filament, you basically short the entire system out.
    Oct 31 2015
    New York
    Okay, so I bought the new bulbs. Still no taillight on the rear passenger. Brake light still goes on though.
    Nov 19 2015
    Buffalo, NY
    I would check every single bulb on the outside of that car and verify they are dual filament.
    Oct 31 2015
    New York
    Well, the other six bulbs are still single filament in the rear, but I couldn't get them to go in... And then I realized any of the sockets besides for the low taillight bulb are single contact. What bulb would I need then? I bought 7528s. So obviously I got the wrong ones for the other sockets.
    Nov 19 2015
    Buffalo, NY
    Oct 31 2015
    New York
    Okay, I had already replaced the parking light, but the rear lights are all single filament, excluding the stop/low taillight. The bulb sockets that are single filament are only a single contact, so wouldn't it be impossible to run a dual filament bulb?
    Nov 19 2015
    Buffalo, NY
    The rear brake lights I think are dual filament? That website I linked you to should tell you if they are single or dual and what bulb is needed. I'd cross reference every bulb for 100% certain.
    Oct 31 2015
    New York
    The bulbs used for braking are dual filament. Would it be possible there is a bad ground or something on the bulb housing?
    Nov 19 2015
    Buffalo, NY
    Yep. I'm not an electrician otherwise I'd help you trace the short down :(
    Oct 31 2015
    New York
    No worries! I appreciate your help!
    Nov 19 2015
    Buffalo, NY
    I wish, and am surprised, that nobody else has pitched in here.
