Results 1 to 9 of 9
Thread: Motor wont turn
    Established Member Two Rings Aferrell71's Avatar
    Aug 09 2015
    05 Ford Taurus
    Christiansburg, va
    Motor wont turn
    After troubleshooting a no start condition, and replacing fuel pump, fuel filter, crankshaft sensor and cam shaft sensor, was checking timing by hand cranking the motor and after 1 revolution and a half now it wont turn at all.
    Please help
    Dec 28 2015
    Wake Forest, NC
    It's in neutral or park, right? Was/Is the cam sprocket moving with the crank? I'd personally move the crank backwards a small amount to confirm, if I were in that situation. If the cam isn't moving you probably have a timing belt problem.
    Sent from my XT1585 using Tapatalk
    Last edited by CaptainJohn; 03-04-2016 at 09:47 AM. Reason: Ambiguous wording correction
    Aug 09 2015
    05 Ford Taurus
    Christiansburg, va
    Yes when cranking the motor the cam sprocket was moving. Could see the timing belt moving. The car is in park
    Dec 05 2007
    Spark plugs removed? Could simply be compression messing with you.
    Were you able to confirm correct timing? I don't suggest turning th engine opposite direction. Parts were designed to be rotated one way.
    Aug 09 2015
    05 Ford Taurus
    Christiansburg, va
    I had 1 spark plug removed. I wasn't able to check correct timing yet. That's what I was looking to do was check timing. Couldn't see it well enough the first time around, so was going to back to check it.
    Should I take out all 4 plugs and do it again?
    I was also told I should take tension off the serpentine belt and check to see if the alternator is locked up, which would cause it not to turn also.
    Veteran Member Three Rings cschuster's Avatar
    Jun 05 2013
    Lexington, KY
    Removing all spark plugs will make it much easier for you to turn. You could also take off the serp. belt. Not a bad idea - that way you're only turning the motor and will have better feel for any binding/contact.
    2011 TTS
    APR Stage 1|H&R Rear Sway|Bilstein B12 Pro-Kit|42DD Downpipe
    2002 A4 Quattro 3.0 6spd - sold
    ST Coils|RS4 Reps|Rebuilt 01E|Color DIS
    Veteran Member Three Rings themadscientist's Avatar
    Oct 10 2010
    Las Vegas
    Verify timing before you do anything else. If that's fine pull the plugs and drive belt.
    2005 A4 Avant 1.8t QTM
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Remove all the plugs and turn the engine in the normal rotational direction. The only resistance will be the cams compressing the valves. If the engine comes to a hard stop you are going to have to remove the head. Take a really close look at your timing belt. I suspect you are going to find a few missing teeth somewhere on the belt.
    Aug 09 2015
    05 Ford Taurus
    Christiansburg, va
    Yes it came to a hard stop. tie to sell her.
